how to remove/ install new rear wheel bearings 1970 cutlass
I have a 1970 cutlass s want to replace the rear wheel bearings can anyone explain to me how i would remove the bearings? I have the type "o" rear end. Are there any special tools needed to remove or install bearings?
thanks in advance
steve
thanks in advance
steve
A slide hammer is the best way to pull the axles, but I've done it by flipping the brake drum around, loosely installing three of the lug nuts (flat side in) and using the drum as a slide hammer. If you really have to wail on it, you can bend the drum, so using an old drum is a better idea.
Oldssupreme
July 31st, 2014 07:58 PM
oldzy
Drivetrain/Differentials
September 14th, 2010 05:40 AM
Classiccarjohn
May 18th, 2010 09:49 AM
nickwhite44
January 21st, 2009 05:07 AM
