Hood hinges
I've seen hinges like yours on a few '68s, including my own '68 442. The thing that's confusing is that the service manual clearly shows '68s(A,B &C bodies all use the same hinge for '68) using 3 bolts on each hinge to the underside of the hood plus a little spacer that goes on the rear bolt, yours only have 2 like mine. My hood has the 3 holes on each side, like every '68 hood I've seen. I was told by someone else that they might be off a Pontiac??, Mine fit fine but I'm thinking of modifying them by squaring up the rounded end with a little welding & adding the 3rd slotted hole. I found a pic online of a pair of '68 hinges,you can see the 3rd slotted hole at the rear. I've never found anything about maybe a 1st or 2nd design on '68 hinges? My 442 is a Nov 67 Lansing car.
Thanks Rob, the hinges look to be the same. I was told they may be pontiac also but Im not sure? I only have 70-72 stuff to compare and Id like to be sure. Maybe Ill check out Pontiac parts and compare.
Early 68's only have two holes. The rear hole with the spacer was an early assembly manual change
They’re $77 each from Ames Performance (without springs) which is still more than you can buy a used set of 68 Olds hinges for.
georgiaboy697
July 2nd, 2010 09:23 PM
Eightupman
February 1st, 2010 10:23 PM
