Function of baffle behing inner fenders of 68 442
Can anybody tell me what is the function of the baffles behind the bottom of the front inner fenders of a 68 442? I just don't get it.
X2...they are a type of water shield. I think for 69 certain 442's + Cutlass had them. W/O looking, I think automatics had them and standards didn't. Something like that. Clearly yours were not installed right originally. Hey...it was 1968. maybe the guy was tripping! Maybe they were going on strike, who knows?
I have many inner liners for '68 (more than a dozen, each side) and I haven't seen any with a baffle...most of my cars are Canadian but even the Vistas and converts do not have that baffle.
All 3 68's i have here have them. Here is a thought. 68 does not bolt the plastic wheel house to the frame down low. They have a rubber bumper and that asphalt thing stapled to it. Now 69, i don't have a 69 at the shop. However i have 3 70-72 cutlass's and all of them actually bolt the plastic wheelhouse to the frame with two bolts down low. No bumper or asphalt thingy.
Having said that could it be there on the 68's for friction/rubbing/squeeking reasons since it is not directly bolted to the frame?
Hi, Here's a pic of the liners out of my '68. Sorry the right side isn't very good. I replaced the main splash shields with the kit from Fusick but the rear ones are the untouched originals. like I said in the other post, mine was a 4 spd car & it did have them on both sides, like most people have said, even though the manual says it's only suppose to have one on the pass side. The one on the left side just hung down.When I got the car back in '12 both of the shields were hanging down but the right liner had been out of the car to replace the blower motor before I got it. It does appear that at one time it was installed correctly as per the manual because its cracked right where it would need to fold up to go over the frame(it's very brittle, being so old) They are supposed to be pushed up over the frame as you install the liner. Hope the pics help you with the placement.
69442C
July 20th, 2023 03:13 PM
