floor shifter problem
I have an 84' 2 door cutlass with the factory floor shift and console. I swapped engine and trans. (removed the 84' 307 and 200c and replaced it with a rebuilt 77' olds 350 and a rebuilt 77' TH 350 trans,)
the floor shift cable wouldn't work, I went to a 77' cable(too long)..I ended up removing ALL linkages and running a B & M cable directly...the cable works fine, but the car will start in Reverse and DRIVE and I have no reverse lights....
Has anyone ran into this kind of problem and, HOW did you fix it?
Help!!!
Help!!!
Help!!!
Help!!!
Did you reinstall the backdrive rod that goes from the trans to the steering column? It is required to operate the backup light switch (which is in the column) and the mechanical lockout on the ignition lock cylinder (there is no longer an electrical neutral safety switch). If you did reinstall the rod, then it sounds like it is not adjusted properly.
according to my guy, we had to do away with the rods...I currently have the B & M cable, and everything that hooks to the shifter part on the trans.(I'm not close to a mechanic) I'm mechanically challenged so you might have to go step by step with me on this....
jstrits
February 7th, 2016 11:33 AM
