Exhaust manifold Assembly
Old September 7th, 2020, 07:09 PM
servexcell's Avatar
Is there a reference in the Assemly manuel in 68 and 69 for Exhaust manifold installation. I was unable to find a refernce
thanks Bruce
servexcell is offline
Old September 7th, 2020, 07:22 PM
What specifically are you looking for? I’m sure there is a torque spec, along with the usual clearance and other checks.
matt69olds is online now
Old September 7th, 2020, 07:24 PM
servexcell's Avatar
i was looking for part no and size of bolts and hardware. Also torque spec
i was unable to find it.
thanks
Old September 8th, 2020, 05:14 AM
The torque spec is in the torque table at the end of chapter 6B in the CSM.
joe_padavano is online now
Old September 8th, 2020, 07:06 AM
Noel Anderson's Avatar
https://pacificgbody.com/blogs/shop/...s-in-one-place
Noel Anderson is offline
Old September 8th, 2020, 10:44 AM
servexcell's Avatar
thanks Joe and Noel . is there a reference or picture of part no. and are the tabs reguired
thanks
Old September 8th, 2020, 10:47 AM
The tabs are just locks to prevent the bolts from loosening up. I hate them. I personally never reinstall them. I'd rather just check the bolt torque periodically.
Old September 8th, 2020, 11:05 AM
servexcell's Avatar
Do they prevent the bolts from getting loose
servexcell's Avatar
i am very surprised there is no refernce in Assemby Manuel
Old September 8th, 2020, 11:40 AM
https://www.ebay.com/itm/1979-Trans-...72.m2749.l2649
Should work on all small block Oldsmobile, these are stainless steel, Inline also sell steel ones for less.
Old September 8th, 2020, 11:55 AM
From my previous post:
The PIM (Assembly Manual) encompasses the assembly operations performed on the assembly line. The manifolds come already bolted to the engine. You need the engine assembly manual for that information. The PIM doesn't have any info on how to assemble the transmission or rear axle, either.
Old September 8th, 2020, 02:44 PM
servexcell's Avatar
Joe where can i find that manual ?
thanks
Old September 8th, 2020, 04:36 PM
I have one for 1969 that I got as part of the PIM reprints sold by Paul Sigmund. They are few and far between. I have not seen a 68 engine assembly manual.
Old September 8th, 2020, 05:09 PM
servexcell's Avatar
Joe would you be able to send the the page for exhaust manifolds
thanks Bruce
Old September 8th, 2020, 05:21 PM
servexcell's Avatar
I just looked through my 69 Assembly Manuel and found a pink section all related to engine. I purchased this also through Paul Sigmund . Thanks for the help.
Bruce
tru-blue 442
March 26th, 2015 07:02 PM
FTolliver
March 28th, 2014 08:12 AM
hurstoldsgal
August 19th, 2011 10:32 AM
D Appeldorn
December 31st, 2009 02:40 AM
oldsracer
September 1st, 2009 03:24 AM
Quick Reply: Exhaust manifold Assembly
