cruise transducer year
Old November 20th, 2017, 05:09 PM
stevengerard's Avatar
Going through some parts and found more cruise control parts. Anyone know for sure what year this transducer is from?
stevengerard is offline
Old November 20th, 2017, 07:39 PM
cherokeepeople's Avatar
mid 70's thru early 80's
cherokeepeople is offline
Old November 20th, 2017, 11:40 PM
tdhill01's Avatar
[QUOTE=stevengerard;1057192]Going through some parts and found more cruise control parts. Anyone know for sure what year this transducer is from?
This was used in the 1970 442/Cutlass models - I have one in mine.
tdhill01 is offline
Old November 21st, 2017, 07:31 AM
[QUOTE=tdhill01;1057245]
That's what I thought. That is what mine looks like and I have had the car since the early 90s but wasn't sure. Mine seized up and I must have found this one at some point as a back-up. The 70 cruise parts seem to be unobtainable so I have no real idea what is correct or not. Looking at the assembly manual this looks right but there is no part number on this (or in the assembly manual)
Old November 21st, 2017, 08:54 AM
mrolds69's Avatar
Not so fast...There were basically 2 transducers used in the 70's and 80's. The big difference is in the number of terminals on the transducers. The one you pictured has two terminals, some have 3 terminals. I'm not really familiar with the 70 Cutlass/442 system, and I'm not near my books. But...I know for a fact my 70 GS455 with factory cruise uses a 3 terminal transducer.
mrolds69 is offline
Old November 21st, 2017, 11:06 AM
Ok, hopefully someone can help figure this out. So far reading the response I have a no, yes and a maybe. And of course my car is not near by so I can't run out and check the difference, if any, with the one on the car.
Old November 21st, 2017, 11:15 AM
kplange's Avatar
I believe that the three prong transducer had the "resume" feature.
kplange is offline
Old November 21st, 2017, 11:19 AM
ok, that makes some sense but in 70 I believe it was either on or off correct? Turn the switch to on, then press the cruise button on the end of the turn signal stalk and that sets the speed. No resume on that.
Old November 21st, 2017, 01:25 PM
tdhill01's Avatar
To the best of my knowledge 1970 442/Cutlass' only had two terminals. My cruise harness has only a plug for two terminals.
tdhill01 is offline
Old November 21st, 2017, 01:31 PM
tdhill01's Avatar
I posted this link a while back and carries some good information about these units. (Forget the title)
http://www.73-87chevytrucks.com/tech...se_Control.pdf
tdhill01 is offline
Old November 21st, 2017, 02:33 PM
thanks I'll take a look
1971 cutlasssupreme
June 20th, 2016 07:27 PM
toymobile
May 9th, 2016 04:08 AM
rcorrigan5
March 30th, 2016 12:22 PM
1BOSS83
March 24th, 2016 04:56 PM
jeffreyalman
March 20th, 2012 05:33 AM
Quick Reply: cruise transducer year
