Crank verification
#44
Ok. He says that since this is a "thick" flexplate, the weight goes towards the block so the converter has a flat surface to mount to. Is this "thick" flexplate going to interfere with my clearance on my spacer kit for my Chevy trans to bolt up? Lol.
#45
No idea, as you are now combining several aftermarket parts not necessarily designed to work together. I've only ever used a factory flexplate and correct BOP trans and obviously had no issues with that.
#46
I know I'm getting annoying and I apologize. This is the first time I've ever messed with a motor to this extent and doing it as a father son bonding thing and with all the frustrations it's backfiring and he is losing interest. Just Need to get it figured out. I guess at this point I'll just bolt it on and see what happens. I really do appreciate all the help!
#48
#49
Sorry I was sick as a dog all weekend. Still am really lol. I have had a couple people tell me this one should work. As long as my clearance with converter is still good I should be fine. I'm going to try it and if not I will have you send me one. Thanks again!
#50
Ok. Flexplate bolted on. Looks ok. Now I thought my transdapt kit had the bolts for converter to Flexplate but I was wrong. So this Flexplate needs bolts with nuts. How in the world do I figure out what size/length bolts I need? I know thread won't matter other than the nuts matching but I see they can only stick through so far without causing major issues. I love oldsmobiles but I think this will be my last, powertrain anyway lol!
#51
#52
Yes I realize I brought it on myself. I just went kinda with the hand that was dealt me, more or less. I just hate asking for help, especially when there is obviously not an easy answer lol. I guess the best way is to just slide the tranny up into place and try to take some measurements the best I can and go from there. Would grade 5 be ok or should I get grade 8 stuff?
