Clutch to flywheel bolts
Need to replace the clutch to flywheel bolts on my 65 442. The original bolts had a shoulder on them. The replacement bolts from Motorcity were threaded all the way. Would there be a problem with these? They said they were as originals.
If you care to go for the extra money, have both the flywheel and the pressure plate balanced as a unit. Many times, after both have been surfaced, the balance is off, enough to cause you a vibration. It is a lot easier to do it now, then to have to take it apart later on due to a vibration that you can't seem to figure out.
1k442
April 29th, 2016 09:38 AM
Beau Dirt
April 28th, 2012 02:21 AM
