Block Casting Number
I have a 1965 Starfire with a 425 cu in v8 in it. The casting number I found on the Block is 888525, for some reason that doesn't seem right. Everything I find on subject indicates it should be 366525, amy help would be appreciated. I found this number above the water pump in and indented horizontal location.
Thanks,
Bob
Thanks,
Bob
Thanks,
Bob
Thanks,
Bob
cstg no.
Joe,
Thanks for your help, I was thinking the same way but it sure looked like it started with 3 8's. Should it be preceeded by a letter.
If casting number is correct what size lifters does it have .091?
Thanks again,
Bob
Thanks again,
Bob
The casting number should be followed by a larger letter "A". By the way, the casting number for a 1965 425 block should be 386525, not 366525. That block should have a 45 deg lifter bank angle and 0.842" lifter diameter.
Joe,
Took your advice and really cleaned the area good, finally i sa the true number 386525. Stll havn't sem the letter yet. Its a tough area to get into w/o removing alternator and power steering pump.
If thet are original heads what should the casting number be and where would I find it. I found this number 35976sor 5, not sure if thsi the correct number or not.
Thanks,
Bob
Thanks,
Bob
Joe,
Thanks,
Bob
Thanks,
Bob
