Belt and Vacuum Line diagrams
Looking for a diagram that show how the belts are routed on a 72 Cutlass w/ AC. Also looking for a diagram on how the vacuum lines are ran on the canister in the right front, carb and the small rounded unit that mounts to the firewall. These are the next steps of my reassembly of my car.
Thank you,
John
Thank you,
John
Thank you,
John
Thank you,
John
Look, seriously, if you don't have at least a CSM, get one. All the info you are asking about is in there. Also, the vac hose and belt configurations differ with different engines and options (AT, AC, etc). The assembly manual has very detailed diagrams of each belt configuration.
Check this thread as starting at post #20 there are some good pictures of the belt routing for an AC car:
https://classicoldsmobile.com/forums...ump-issue.html
