Which ATF ?
Dexron III / Mercon has worked just fine in early Hydramatics .
If you have old or original fluid in it , I would suggest draining it from both the pan and the torque converter . (The converter has a plug in it .) And refilling with new fluid .
Should take about 10 to 12 quarts .
