Alternator brackets
Alternator brackets
So I bought a new alternator which is bigger than my original one but it didn’t fit the brackets were to small and I can’t adjust it were can I find a bracket that will fit in my 350 rocket need help
Benny:
Did you buy a CS130 or CS130D? The CS130D is too large and will not fit the factory brackets. Here are 2 pics of the CS130 I recommended to you from Tuff Stuff. The part number for a natural finish (not polished) is 7935k-11G and it's rated at 160A. With the exception of the factory rear brace, it fit my '72 brackets without any issues.
Rodney
Rodney
Benny:
Rodney
Rodney
What series is the alternator? Can you post some pics?
The only alternators ever used on Olds motors were the 10DN (external regulator), 10SI, 12SI, and CS130. All four of these used exactly the same dimension between the two mounting bolts, so they all interchange in any 1963-1990 Olds V8 brackets. There are no factory brackets that accept a larger alternator. Your only options are to find an aftermarket set of brackets or fabricate your own. I am not aware of any aftermarket brackets that can accept a larger alternator for Olds motors.
brandon reynolds
January 12th, 2019 05:48 AM
olddaz
August 27th, 2014 06:39 PM
