72 Cutlass convertible Window Tilt?
My passenger window and back seat rear window do not line up when they are both rolled up.. It appears that the back window is tilted in too much at the top. Is there some kind of adjuster for this?
If you can post a picture of the window's offending gap, I should be able to steer you on course. I ~think~ I know what you mean but need to be 100% sure.
I had to readjust all of mine, and the mechanism is what is adjusted.
Thanks Rob
I'll post a couple of pictures tomorrow
Also I noticed tonight that there was an eletrical plug hanging down below the car. I can't see where it is supposed to go - could be from the engine compartment I'll post a picture of the plug too- maybe you can identify it.
Window gap pictures and mystery plug
I'd like to get rid of the gap at the top of the window. I can't tell for sure if the back window is off, or the front, or both.
As far as the plug, I pulled it up throught the engine bay but originally found it hanging under the car. It looks like the wire goes into the firewall. Any idea where this should plug into?
ELECMAN
January 22nd, 2012 01:49 PM
leepear
April 22nd, 2011 02:22 PM
