71 Delta 88 Steering Column.
No big deal, it's actually a pretty easy job.
If you want to change the steering wheel or ignition switch you'll need a steering wheel puller and lock plate remover tool.
The only "How To" is the 1971 Oldsmobile chassis service manual.
If you promise to get the car's instructions in the future... I'll tell you that if you register at Wild About Cars Online then go to the downloads section you can look at the '71 service manual.
The column removal and installation instructions start on page 9A-60 in the steering section.
http://wildaboutcarsonline.com/index.html
starfire
December 9th, 2021 08:21 PM
317Cutty
June 18th, 2014 10:53 AM
ros6872
March 28th, 2014 09:48 AM
