67 Cutlass auto floor shifter placement/location
Hi Guys,
I am finally doing my bucket/console conversion on my 67 Cutlass.
I got the buckets in, now it's time for the shifter.
Anyone have measurements as to exactly where the shifter mounts to the floor ?
Also measurements on where the hole goes for the floor shifter cable ?
Also found this "key card" under the carpet..found it interesting
Thanks in advance
Thanks in advance
I dont have the measurements you need, even though mine is a floor auto, its all covered now and no time to measure. Someone here will have those measurements you need. I have used Lectric Limited wiring harnesses, they have the console extension harnesses for the neutral safety switch and console lighting. Very nice quality. I think M&H also has these harnesses and probably American Auto Wire. I love that color interior on one.
Good luck
Steve
Good luck
Steve
Thank you,
I think I got it in the right spot.
I had to fab a new bracket for the attaching point on the transmission and trans pan, but car won't go to 2nd or 1st.
I ordered the correct (hopefully) brackets yesterday.
http://www.jegs.com/i/B%26M/130/3549...gn=retargeting
Lets see what happens with the new brackets.
Then I have to figure out the neutral safety switch and reverse lights...ugg
Good luck
Steve
Good luck
Steve
arodenhiser
November 15th, 2010 02:06 PM
1960es
September 4th, 2009 03:02 AM
