66 backup lights
They feed into the wiring harness that runs from left side tail light to right side tail light. There is a hole in the trunk floor just below the trunk lock that the wire passes through with a rubber grommet to seal it.
I have to charge you those fender vents for this tidbit of info
Thanks Trip I thought thats where they went with the fuel gauge wire or lic plate light than. you will have to do better than that for the scoops though.I built my trunk floor it was pretty bad wasnt sure if I missed something for the wires to go through
The hole near the trunk latch is for the license plate lamp. The pair of backup lamp wires, joined like a 110 volt lamp cord, feed through a small hole in the vertical body panel below the tail lamp that is hidden by the bumper. The hole has a grommet and is about 3" above the pinchweld at the bottom of the quarter.
OK now its comming back to me I took this car apart in the early 80's THANKS A BUNCH I will start looking to see if I still have those holes or I will drill some new ones I put alot of new steel on it.
oldstuff
September 13th, 2011 08:03 AM
