1959 Olds windshield trim
Hi, I'm in the process of replacing the windshield on a 59 2 dr ht, the old windshield was broken out. I'm having trouble getting the top and bottom clips to release and havent had any luck finding out how to do this yet.
Does anyone know the sectet?
Thank you
Thank you
If I remember correctly, after you unbolt the top clips and remove a screw from each end of the top, the windshield will push out from the top. Also must remove the cowl screen on the bottom (I think) to reveal the bottom clips which are not actually fastened to the body. This assumes you have both sides already removed. Also easier if you cut the rubber seal all the way around. The manual has a pretty good explanation and illustrations.
fzadnik
July 31st, 2015 05:48 PM
Oldssupreme
May 28th, 2013 05:35 PM
