1968 442 seatbelts
Old September 27th, 2015, 11:31 AM
glennmills's Avatar
1968 442 seatbelts
Should the 1968 442 have seatbelts in the back? I only have the lap belts in the front bucket seats.
glennmills is offline
Old September 27th, 2015, 01:05 PM
Randy C.
rcorrigan5's Avatar
Yes, the back seat should have seatbelts as well - 3 sets. Have you looked behind the seat bottom cushion assembly? Someone may have shoved all the seatbelts between the seatback and the seat bottom cushion where they can't be seen.
Randy C.
rcorrigan5 is offline
Old September 27th, 2015, 05:51 PM
They may be under the rear seat or they were like me and removed them. If they had been removed I'm sure someone on here may have a set.
oldcutlass is online now
Old September 28th, 2015, 06:46 AM
It was not uncommon for the rear belts to get pushed into the gap between the rear seat back and seat bottom cushions. Federal law required lap belts at every advertised seating position, and shoulder belts for the front outboard positions (except on convertibles) for the 1968 model year. Every car built by Olds that year came with them from the factory.
joe_padavano is offline
Old September 28th, 2015, 08:34 AM
glennmills's Avatar
Thanks for the info. I had my son check but I guess I'll have to check for myself. You know what they say about a job done right!!
Old September 28th, 2015, 04:32 PM
Randy C.
rcorrigan5's Avatar
The best way to see is to pull the back seat bottom cushion. There are two tabs in the lower front of the seat cushion that need to be pushed back so they can clear the "hook" that holds the tab in on each side. Once the seat bottom is out, you will either see your seat belts or you will see where they were anchored!
Randy C.
Old September 29th, 2015, 04:07 AM
glennmills's Avatar
Thank you Randy
Old September 29th, 2015, 01:14 PM
Indy_68_S's Avatar
Hopefully, you'll find them ...and not like mine where a PO had cut them off about a foot from the floor bolt
Indy_68_S is offline
dnmfranco
October 27th, 2013 06:10 PM
Saintsinner78
April 9th, 2012 05:37 PM
derek nesdoly
September 2nd, 2009 04:26 AM
pobi442
June 11th, 2008 11:14 AM
JSGD1966
October 30th, 2007 01:39 PM
Quick Reply: 1968 442 seatbelts
