1966 oldsmobile 330 engine head bolts and manifold bolts
If you need the head bolts with the stud on top for accessory mounting, you won't find them aftermarket except from an Olds specialty vendor. More to the point, you don't need to replace your head bolts if they are in good shape. These are not torque-to-yield like on newer vehicles, so they can be reused if not damaged. Manifold bolts can be replaced with grade 8 bolts from a hardware store if needed.
stanzaschance
August 12th, 2015 07:45 PM
Eightupman
November 13th, 2012 05:16 AM
