Matador Red 70 Cutlass Cruiser barn find
#41
I got some Walker oem 442 headpipes with my last parts car and welded some stock length Walker Super turbos on myself. Headpipes need 4" added technically for wheelbase. I will buy tailpipes or have done.
#43
Been driving the wagon a lot with the freebie temp motor and finally tearing into the original 310 hp one. Knowing it had a spun rod bearing but otherwise seems excellent. it has very little to no sludge inside and the cranking PSI was really high , the low cylinders were 180-190 and the others were 210 or more. The bad rod bearing was #7 as that is the only piston with carbon off at top where its kissing the head. Valves look good too. Should be a easy re ring , crank job build (plus cam). The tough part is to decide if I am stilling doing bigger valves or not or just save the money. No plans for headers anyway. The ported head motor for Rallye is getting headers so at least one will.
#44
Ran the low compression stock 350 at the 1/8 mile tonight just to see and it was back to back 10.20@68.5 with light tire spin(x2) 2.2 60 ft. So what was a 7.9@86 has slowed a bit LOL
#46
#47
Cruising with original engine back !
I have not been on much in a while but during this work from home time I finally got my original engine together and back in running good. Already cruised over 100 miles monitoring temps and oil psi. All good no leaks runs good. I added headers to car a while back and using a 79 TA 403 shaker base for HEI clearance cause I had it laying around. Also for first time since I had it the inside panels are back on. The beer run wagon is good to go !
#51
Updates ! https://youtube.com/user/larryparks69
The old wag got some Maaco paint and body (plus the hood upgrade) , not a show car but pretty driver for the road and track man! Matador Red !
#53
Had to get the dust and bird poop off after putting new stock upper A frames in place of previous tubular ones along with a 800 Q-jet from a 403 and new pretty plated brake booster , master and hold off valve and exhaust leak fixed at header collector.
#54
#57
Wagon wins Modified Muscle
1st race of the 2023 Texas Muscle Car Club Challenge series yesterday and brought the wagon and went rounds and took the Win in my class ! This class allows me to use same racer # points and bring different vehicles to different races and keep points in one class.
#61
Tedd Thompson
November 18th, 2014 09:16 AM
