Bolts are bolts.....Right?
Old December 23rd, 2014, 04:36 PM
Sampson's Avatar
[IMG][/IMG]
These bolts were taken out of a 88 Jeep Grand Wagoneer project I am working on. It is not a very rusty vehicle. I Reused 95% of the bolts when I restored my 1972 Cutlass. i don't think Jeep used the same quality bolts as GM. Could it be the difference in metal quality that GM specified or had all OEM material quality degraded to this point by 1988?
Sampson is offline
Old December 23rd, 2014, 04:39 PM
It's the difference of the coating.
oldcutlass is online now
Old December 23rd, 2014, 04:55 PM
Sampson's Avatar
Too long in the Muratic acid??????????
Sampson is offline
Old December 23rd, 2014, 06:32 PM
Octania's Avatar
Steels vary, surface treatments vary, and conditions of use vary. I'd venture to say on an AZ or TX car, one could re-use 100% of the bolts.
Octania is offline
Old December 23rd, 2014, 06:34 PM
66-3X2 442's Avatar
It's a Mopar thing.
66-3X2 442 is offline
Old December 23rd, 2014, 08:36 PM
I believe you've found the bolts that everyone has been looking for. They're quite rare and made of Softenite. Reason they're so rare is they don't last long.
Find some real bolts - there's lots of guys here who part out cars that could ship you tons of rusty bolts that just need a small bit of clean up.
Allan R is offline
Old December 26th, 2014, 06:07 AM
'87 Delta 88 Royale
rustyroger's Avatar
Bolts are are bolts, but only the correct bolt is right for the job. Do you need high tensile bolts for high loads?, corrosion resistant bolts for marine use or use in industrial chemical processes?, bolts designed to break at a predetermined load?, bolts designed to stretch as used in many engines nowadays?.
When I was at school the metalwork shop has a book listing various threads and materials used in bolts. Or as the teachers insisted, fasteners. It was about the same size as a bible.
Roger.
rustyroger is offline
Old December 26th, 2014, 06:23 AM
drop top olds's Avatar
Even spec'd bolts can be a problem. Around 2010 there was a real problem with the A-325 bolts used by the structural engineering community. Seems there were some sub-standard bolts out there snapping off when using the "turn of the nut" method. The point of origin for these A-325 bolts was.........China. I was shocked (not). Industry quickly identified the bad lots.
So yeah. not surprised about bolt quality now a days.
drop top olds is offline
Old December 26th, 2014, 06:57 AM
FMB42's Avatar
Yep, this issue crops up from time to time. A decade or so ago a U.S. high rise steel worker feel to his death when the bolt he was torquing down snapped off causing him to lose his balance (he wasn't wearing the proper safety gear IIRC). These bolts were also from China (which is not at all surprising to anyone who works with machine type products from that country).
FMB42 is offline
Old December 26th, 2014, 06:15 PM
Fastener issues crop up all the time. There was an issue related to amusement park rides due to bolt failures about 15 years ago. There were issues with fasteners in the aircraft industry before that. I don't think the OPS issue is related, his is the climate in which he lives and a manufacturers choice in fastener coatings.
Old December 28th, 2014, 07:41 AM
twintracks's Avatar
GM is not immune. We have a '98 GMC 2500 4 wheel dig that has had a hard life as a plow truck in Wisconsin. The exhaust manifold bolts completely dissolved, leaving the manifolds falling loose. We had to pull the heads to fix it correctly. Amazingly, the body is still looking good except for the tailgate, and the very bottoms of the doors. Funny thing too is that it's completely free of dings, because it's never been parked in parking lots.
twintracks is offline
stanzaschance
July 28th, 2015 06:38 AM
nolabigdawg
October 25th, 2014 11:50 AM
Oldssupreme
February 6th, 2013 12:39 AM
RAMBOW
August 24th, 2012 11:18 PM
Redog
November 15th, 2006 09:27 PM
Quick Reply: Bolts are bolts.....Right?
