1969 Cutlass Tire Pressure?
Hi guys!!
I have a 1969 Cutlass Supreme (V8 350), holiday coupe, auto trans with modern 205/75 14''.
Need to check tire pressure and wondering what would be the correct tire pressure with modern radial tires.
I found on the site that with old ply tires, it should be about 26psi, but what about new radial tires?
Thanks a lot for all your help!
Fyi
35 psi up front & 30 psi out back. Chalk your tires across the tread then roll the car forward & see what is left of your chalk mark. Once the chalk mark is gone across the entire width of the tire tread then you have the right psi. If you only wear off the chalk on the middle of the tire you have too much pressure.
Class is over.
Class is over.
Most older bias ply tires were set at around 28. For newer tires, each manufacturer is different I run 30#'s in my BFG's. It really depends on the max pressure rating per the weight capacity of the tire.
Radial tire pressure.
Wayne
Chalk test
I leárned that chalk technique from an older enthusiast about 30 years ago. It just flat out works and I share it when asked about air pressure. Feel free to pass it along to others.
