Ignition Switch Won't Turn to Start 1975 Hurst/Olds
Old August 10th, 2014, 06:57 PM
Hurst/Olds 73/74's Avatar
I found a 1975 Hurst/Olds that I'm interested in buying. It's been stored outside for several years. I went to start it this week and the key won't turn all the way to the "start" position. It goes backwards to the auxiliary position and forward part way, but gets jammed up. I pulled the old ignition switch out and it turns ok out of the column. I also put a new ignition switch/key into the column and it does the same thing. I don't want to pass on the car and I REALLY don't want to buy it and change a steering column. It's a 1975 Hurst/Olds W-25 with tilt column and Hurst Dual-Gate shifter on the floor. I did check that the shifter was all the way in "park" and the column cover was turned all the way. I also tried the tilt in several positions, but nothing helped. It seems that something is jammed up beyond the ignition switch. Any ideas?
Also, if I need a new part, can I find the same part in any column-shifted '73-'77 Cutlass?
Hurst/Olds 73/74 is offline
Old August 10th, 2014, 08:03 PM
Paladin31's Avatar
Only key cylinders are the same, tilt column parts unique for tilt columns, bearings and switches etc are different. double check to make sure the pushrod is fully engaging column switch and that switch is sliding freely to 'on' position, ill bet it is binding and not fully positioning to the 'start' position.... that the console shift linkage has gotten dry, or jammed. Wild About Cars has adjustment procedures in section 7 sheet 1 for this problem on 75 cars. Good luck!
Paladin31 is offline
Old August 10th, 2014, 09:07 PM
I went to Wild About Cars, but couldn't find the section you were referring. Can you type a link to the section or navigate me there?
Old August 11th, 2014, 10:01 AM
Paladin31's Avatar
Help
Go to Wildaboutcarsonline.com
http://wildaboutcarsonline.com/cgi-b...=9900334159517
In the Olds' section...click-Factory Publications...Click-Assembly Manuals...Click-1975...Click-1975 Olds A-body Assembly Manual...scroll down to section 7 and double click to download. Open that up after D/L completes, and read this section, many pages have information that you may find useful. Best of Luck.
Brett
Old August 11th, 2014, 12:08 PM
I got it now. Thank you!
stevengerard
September 10th, 2014 03:17 PM
Sestius
15
July 22nd, 2012 11:18 AM
SkylinesSuck
January 5th, 2012 01:22 AM
dennisspeaks
September 24th, 2011 01:10 PM
justinj
August 26th, 2008 12:59 PM
Quick Reply: Ignition Switch Won't Turn to Start 1975 Hurst/Olds
