Automatic transmission shifting issue?
Hey all. This was the first weekend of cruising weather with the new to me 442. Had some work done to it over the winter but nothing major with regards to the engine. Took her out yesterday for a quick ride around town mostly residential and top speed of 45. All seemed to be great. Went to take the family out today and upon startup noticed a strong gas odor. Rpm slightly higher than usual when warmed up. Shifted in and out of reverse and drive and neutral without issue but would not shift out of first while driving. RPMs topped out at 3000 ish. Didn't go far before coming home. Any initial thoughts?
Kurt
Kurt
Probably the rubber hose to the modulator either the connection to the metal tube on the engine side or the at the transmission. The higher rpm is a symptom of a vacuum leak created. If not the hose, then possibly the modulator itself as Eric suggested or the governor as suggested by Hairy Olds.
The reason I went right for the modulator was the "rich" smell, which could be burning ATF (sorry, I didn't mention that above), and the overall timing of the failure, after a first run after being stored a while - a hose probably won't just develop a leak like that, but a diaphragm can sit for many years, then fail suddenly the next time it's subjected to vacuum.
But, yes, of course, you should do all of the proper troubleshooting before putting down your hard earned money.
Also, unusual white smoke in the exhaust, also due to ATF getting sucked into the engine and burned? This was a symptom I had on a '64 Jetstar some years ago. New modulator cured it.
I would lay under the car and do a quick check of the vacuum line to the modulator and the modulator itself. Check the vacuum hose for cracks and/or transmission fluid inside. Modulators are easy to change, take about 10 mins.
Then of you can't figure it out then make the slow trip to a mechanic while watching your temps.
yeahbuddy
August 9th, 2010 09:58 AM
