Wall of shame
Old December 3rd, 2017, 09:07 AM
  #321
Justin
oldstata's Avatar
Your muffler brake pads are worn out , we can do that for a low price
oldstata is offline
Old December 3rd, 2017, 09:10 AM
  #322
At least they retained the rubber mounting...
MDchanic is offline
Old December 3rd, 2017, 09:31 AM
  #323
Maintained
scottv442's Avatar
Originally Posted by oldstata
Just did brakes and has horrible grinding noise
bin there
scottv442 is offline
Old December 3rd, 2017, 04:23 PM
  #324
JohnnyBs68S's Avatar
Might be lame compared to most of the pictures / stories on this thread, but is true.
Back in '97, I purchased a low-mile '94 Z28 Vert, great shape, but got such a good deal I had enough left over to buy a winter beater to save the wear and tear on the Z. Picked up a '84 Nissan King-Cab pickup for $800, rusted to beat all hell. The lower fenders on the bed had rusted off (from a distance, you could see light between the frame and bottom of the bed.......I know you've seen them like that) and it was held to the frame w/ one bolt. That was the first thing I repaired, followed by making sure all fluids were OK and no major leaks to get me through the winter. All winter long, it had a severe back fire, so harsh sometimes that it would buck and chirp the tires even in 2nd gear! Following spring I tackled that w/ a full tune-up. Discovered the cause of the back fire, it was the distributor cap that was loose because it was being held on w/ only one screw that wasn't even the correct fastener. I'm lucky I didn't get stranded. Ended up getting 2 useful years out of that truck, one time carrying 2600 lbs of gravel for my g/f's driveway (someone had bolted on "helper springs" that kept it from bottoming out on the rear axle), and multiple loads of hay for her horse. One time had two ~6' x 5' rolls strapped into the bed, another with the help of some plywood sides I built, had bales stacked so high that it created so much aero-drag I couldn't get it to go over 50 MPH. Ended up trading it in for more that twice what I paid for it. Definitely got my $800 worth out of that beater.
JohnnyBs68S is online now
Old December 11th, 2017, 10:02 AM
  #325
Justin
oldstata's Avatar
Found this on a fb group hopefully it’s a fake hahaha
oldstata is offline
Old December 14th, 2017, 09:33 AM
  #326
TripDeuces's Avatar
Saw this today on FB.
TripDeuces is offline
Old December 17th, 2017, 07:42 AM
  #327
zeeke's Avatar
Does that qualify as a tubular lower control arm?
zeeke is offline
Old December 17th, 2017, 06:01 PM
  #328
If he welded it right, it may be stronger than the original.
Koda is offline
Old December 18th, 2017, 07:09 PM
  #329
Justin
oldstata's Avatar
with re bar ? Not sure about that lol
oldstata is offline
Old December 18th, 2017, 07:18 PM
  #330
Justin
oldstata's Avatar
Yes we caught fire
oldstata is offline
Old December 19th, 2017, 05:12 AM
  #331
72Cutlass S
gs72's Avatar
I have never seen one of these break. It's out of an Eaton 18 speed trans from a big rig. This part came out of a hydro-vac truck that had the vacuum blower lock up during operation. It blew up the transfer case and snapped the input shaft all at the same time. They run these units in 18th gear at 1200 rpm. That's probably around 2000 lbs. ft of torque when it all let go.IMG_0405.JPG
gs72 is offline
Old December 28th, 2017, 07:15 PM
  #332
Justin
oldstata's Avatar
oldstata is offline
Old December 28th, 2017, 07:28 PM
  #333
Gary M's Avatar
10 more miles and those will fit. Gives new meaning to " break in period!"
Gary M is offline
Old December 28th, 2017, 09:13 PM
  #334
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Thats what that rub block is there for...one size fits all just needs to "lap in" a lil...LMAO. Driver never heard it either...oy.
droldsmorland is offline
Old December 29th, 2017, 03:25 AM
  #335
Gary M's Avatar
Seems like it would sound like a bicycle with playing cards flapping against the spokes as you roll along!
Gary M is offline
Old February 23rd, 2018, 03:45 PM
  #336
Justin
oldstata's Avatar
Customer exhaust hanger welded to the rear toe cam bolt
oldstata is offline
Old March 7th, 2018, 05:26 PM
  #337
zeeke's Avatar
This came from a G-body post another member found.
zeeke is offline
Old March 7th, 2018, 06:12 PM
  #338
Gary M's Avatar
That will buff out
That looks like shear determination at its worst.
Gary M is offline
Old March 9th, 2018, 12:12 PM
  #339
golden rocket
golden rocket's Avatar
About 1977 I was working in a small, independent shop. Elderly lady came in with a 1961 Ford sedan, 6 cylinder 3 speed. Said her car was running awful, must need another motor or something. I said we should run it up and down the service drive a couple of times, so I could better understand exactly what she needed. I drove it, with no problem, back and forth. And she told me I was driving it wrong. She shows me how she drives it, and it runs like a dog. I'm scratching my head at the change, so ask her to show me how she starts the car to drive it. "Well Ford put this nice purse hanger, right here for me" She had pulled the manual choke out enough for her purse to hang on.
golden rocket is offline
Old March 15th, 2018, 05:51 AM
  #340
Justin
oldstata's Avatar
14 mile wrx 2018
Making horrible sounds and I am just learning how to drive a manual .........
oldstata is offline
Old March 15th, 2018, 06:07 AM
  #341
Funkwagon455's Avatar
Fourteen miles!!
Funkwagon455 is online now
Old March 15th, 2018, 07:09 AM
  #342
cjsdad's Avatar
What gear is that and how can it get that damaged that quickly?
cjsdad is offline
Old March 15th, 2018, 08:15 AM
  #343
Indy_68_S's Avatar
Ha. No need to use that third pedal. It's just for decoration.
Indy_68_S is offline
Old March 15th, 2018, 10:33 AM
  #344
Justin
oldstata's Avatar
1st gear and it’s on the reverse assembly lol
his actual complaint was” just bought this and I don’t know how to drive it and it’s making a horrible sound luckily I am not the tech working on this lol we have to reach 91% before a full replacement can be made and it’s at 87 hahah
oldstata is offline
Old March 15th, 2018, 11:50 AM
  #345
72 Olds CS
RetroRanger's Avatar
Ouch return it NPF should reach 91% by the end of the parking lot
RetroRanger is offline
Old March 15th, 2018, 01:06 PM
  #346
344879M363895
70-442-W30's Avatar
From my B&S-powered Snapper riding mower:
70-442-W30 is offline
Old March 15th, 2018, 04:35 PM
  #347
TripDeuces's Avatar
That ought to do it
Old March 16th, 2018, 01:54 PM
  #348
kenmosher's Avatar
Too much boost ... not enough fuel ...
Back in about 1990 ... we were at a Friday Night No Prep night ... I had slicks on my Grand National and some high school kid ahead of me tracked water in his freakin' snow tires on the track. Launched the car and it actually hooked well (low 1.60 short time) and then about 100-150 feet out it spun so fast I couldn't catch it. Heard it pop and just figured it was the hoses on the intercooler (they'd pop off on overboost a lot of times). Little did I know ... Sort of peddled it and coasted to the finish line to be met by the firetruck!
When the piston melted, crankcase pressure shot up and it puked oil out of the valve cover breathers. The oil ran down the hot downpipe and where it dripped off under the car it caught fire. People told me it looked like a jet under the car!
VERY fortunately as I bailed out ... a little squirt of water put it out and when I got it home and tore it down I found this piston. There was a scorch mark on the downpipe and it was greasy, but that all cleaned up with some steel wool. Didn't even mark the underhood paint! Ended up rebuilding the engine using a new block since that piston had lightly scored the original block in that hole (I still have that block). Funny thing was, really no damage anywhere else in the motor! Looked brand new and never did find that piece of missing ring!
Car was running mid/high 11s back then and still "the family car".
kenmosher is offline
Old April 18th, 2018, 12:14 PM
  #349
Justin
oldstata's Avatar
I am sure there are better ways !!!!!
Quote from the tech that found it “Fishing accidents are a viable alternative to divorce. THIS will get you caught, buddy.”
My husband replaced my brake lines a week ago 😮😮😮
oldstata is offline
Old April 18th, 2018, 03:28 PM
  #350
zeeke's Avatar
Wow & wow!
zeeke is offline
Old April 18th, 2018, 07:05 PM
  #351
My wife brought the car in?!?
MDchanic is offline
Old April 24th, 2018, 09:40 AM
  #352
TripDeuces's Avatar
http://machineusa.org/2018/04/23/bes...tion-jan-2018/
Some of these are great.
Old April 24th, 2018, 11:09 AM
  #353
Hilarious
Jamesbo is online now
Old April 27th, 2018, 11:27 AM
  #354
Jeff
Weezer's Avatar
Saw this on a FB ad for a '76 Cutlass, "some metal was replaced on body can see in pic". At least it's not plywood, I guess...
Weezer is offline
Old May 11th, 2018, 04:42 AM
  #355
zeeke's Avatar
Got this dosey off facebook.
zeeke is offline
Old May 11th, 2018, 05:45 AM
  #356
Justin
oldstata's Avatar
Found this one on fb too lol
oldstata is offline
Old May 11th, 2018, 05:56 AM
  #357
The old 1 million amp fuse.
That zip tie trick WOULD get you home, provided it held air.
Koda is offline
Old June 24th, 2018, 02:34 AM
  #358
zeeke's Avatar
Here we go again, a set of restricted headers for the low price of $85. Add says never installed and they fit Chevy, Buick, Oldsmobile, Pontiac. I guess they are universal and pre-crimped. Never installed??? How did the hot spots get there a torch? I've heard this theory before... "When all else fails bash it with a hammer."
zeeke is offline
Old August 18th, 2018, 02:47 PM
  #359
Justin
oldstata's Avatar
Found a video on fb and had to screen shot....
oldstata is offline
Old August 18th, 2018, 03:02 PM
  #360
costpenn's Avatar
From the front axle of a 79 Ford F-250 4WD I'm doing a resto on. It took me a minute to figure out what had happened
costpenn is offline
Quick Reply: Wall of shame
