Wrong water pump? Pulleys don't line up
Old May 15th, 2013, 12:39 PM
Finn5033's Avatar
My crank and water pump pulleys don't line up. They are both correct year 3 groove for a/c. Is it possible the parts store ordered the wrong water pump? The water pump pulley looks like it sits in too far. I don't understand because the original water pump looks to be the same length as the new one
Finn5033 is offline
Old May 15th, 2013, 02:31 PM
Finn5033's Avatar
Anyone? I am at a loss for words on this one
Finn5033 is offline
Old May 15th, 2013, 02:35 PM
66luvr's Avatar
The flange which the fan bolts to is pressed on the shaft. I have had water pumps that were correct for the application but the flange was not positioned correctly. I distinctly remember the last time the flange was pressed on too far. Pulleys would not align. You may want to check it out.
Mike
66luvr is online now
Old May 15th, 2013, 02:41 PM
Finn5033's Avatar
I see what your saying, is there a way to adjust that?
Finn5033 is offline
Old May 15th, 2013, 02:54 PM
DarrylJ's Avatar
The a/c water pump is taller than the non a/c one. I ran into that on my 70.
DarrylJ is offline
Old May 15th, 2013, 03:16 PM
Finn5033's Avatar
I'm not sure what you mean? My issue is the water pump pulley sits too far in so the grooves don't line up
Finn5033 is offline
Old May 15th, 2013, 03:21 PM
halfmoontrail's Avatar
Just trying to help - is it possible you stacked the crank pulleys wrong? they look freshly painted, and IIRC its a 2-v and a 1-v pushed together.
Steve
halfmoontrail is offline
Old May 15th, 2013, 03:54 PM
oldspackrat's Avatar
I've installed a washer or two on each water pump stud before to move the pulley out a bit?
oldspackrat is offline
Old May 15th, 2013, 04:01 PM
Finn5033's Avatar
Ok I will just use washers to shim it out then. Thanks for the help guys
Finn5033 is offline
Old May 15th, 2013, 04:03 PM
Finn5033's Avatar
Steve
I am pretty sure it's right. Don't worry I won't take offense to any suggestions. I am a rookie when it comes to this stuff
Finn5033 is offline
Old May 15th, 2013, 04:40 PM
Railguy's Avatar
I had the same problem with my Omega.I bought a new water pump then it was a long time till I installed it.So I couldn't take it back.I just bought another one and it worked.
railguy
Railguy is offline
Old May 15th, 2013, 07:42 PM
Did you have the Harmonic balancer off? (looks like engine nice and clean) Wondering if maybe balancer isn't in as far as it was?? Or if only thing you changed was water pump then not that....
Greg Rogers is offline
Old May 15th, 2013, 08:36 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Looks like the wrong water pump.
KC crank goes with KF water pulley and a 5.6" pump.
There are 3 water pump snout lengths. 5.1, 5.6, and 6.1
Looks like you have 5.6 pulleys and a 5.1 pump
J-(Chicago) is offline
Old May 15th, 2013, 08:42 PM
It's easy enough to measure.
See here.
MDchanic is offline
Old May 16th, 2013, 02:24 AM
5998DownUnder's Avatar
Would there be a chance here that you can get (like the chevy) a short and a tall water pump?
Also as Greg Rogers mentioned re the harmonic balancer. Is it on far enough, just stood out to me as soon as I saw the picture.
5998DownUnder is offline
Old May 16th, 2013, 03:25 AM
DarrylJ's Avatar
See here.
That's what I meant. Way better explanation but I guess I was on the right track.
DarrylJ is offline
Dave Siltman
July 24th, 2014 02:55 AM
1950 Model Olds
July 20th, 2011 09:12 AM
1965cutlassragtop
June 4th, 2011 08:47 AM
crazy'boutOlds
August 24th, 2009 07:36 PM
silverriff
June 9th, 2008 02:43 PM
Quick Reply: Wrong water pump? Pulleys don't line up
