Stick flywheel casting numbers
Does anyone have the casting numbers of Olds stick flywheels? Both the early style 64-67 and the later style 68-76 thanks any help would be appriceciated. Larry
As far as I know,there are not any casting/part #'s on Olds stick flywheels. The only way I know to check which wheel you have is to actually install it on a crank. I cut the end off an early 64-67 crank and that's what I use for identification. If anybody knows otherwise,please advise.
