Our new Technical Editor/Moderator
#45
Ralph
#53
I have also read many of Joes replys to questions and his comments. His knowledge is amazing! He has also helped me as many others here have. So thanks to Joe and many others here for your willingness to help.
Steve
Steve
#55
Help, I am putting a ls1 in a 65 f85/cutlass/holiday.. I am having trouble getting it to sit on motor mounts because of the k-member and stearing linkage. There is one I find on Hot Rod mags page. I am trying to find out Who it is? and a contact number.
Is the cutlass A-body frame different a malibu A-body?
I have quit a few bucks tied up in this swap. I really need some help here??
Gary
Gary
https://classicoldsmobile.com/forums/non-olds-powered/
#58
on a thread about disc brake conversions on an"A" body.
I was in the process myself of doing such a conversion at the time and mentioned
what was supposed to be the correct length hose seemed too short.
You mentioned you had done several of these conversions and the original length hose worked fine.
Well, you were right.
I didn't consider the fact that the car was jacked up and the shocks were fully extended.
Once on the ground, the original length hose worked fine.
I won't question "the Guru" again.
#59
I own a '67 442 but anytime I see Joe Padavano on a posting, no matter what year it concerns, I read it because the guy always has straight answers and I often learn something. Glad he's here for us.
#65
Advertisement limiting site access
I have noticed that for some time it has been difficult to use the menu bar that is towards the top of the page. It has the links to Gallery, user CP, FAQ, Community, Calendar, New Posts, Search Quick Links, Vendor Directory, Used Cars and Log out. What I am experiencing is that if you direct the cursor over each of these headings it drops down a secondary menu of places to navigate to. The current advertisement just below it is for FORD,. the drop down menus are going behind the advertisement making it not possible to access the drop down menu options.
I am wondering if there is a cure for this? Is is something I need to do to my computer or is it a site issue?
Thanks in advance for any guidance on this.
Thanks also for a great site.
Larry
Larry
#66
Larry
Larry
I have the same problem but everyone that responds will tell me that it's because I use IE, don't have AdBlock, etc; so it's really my fault
#69
I just tried it using Edge on my Win 10 machine (without adblock), and no problems there either.
tomc5
April 20th, 2013 10:44 AM
