68 442 Convertible Switch/Relay Wiring
Old June 20th, 2011, 07:34 AM
Tom442's Avatar
I have all 3 bookss for 68, CSM, Fisher Body and Assembly Manual. I cant locate any diagram or schematic for the convertible stuff. Is there a hot wire right out of the fuse block on the engine side to the relay and the orange wire to the top switch off the other side of the relay? Or am I way off base.
Thanks for any help!
Tom442 is offline
Old June 20th, 2011, 07:41 AM
Lady72nRob71's Avatar
For my 72 it is in the body manual. I missed it several times, since it was mixed in along with the power window and door locks.
Doesn't hurt one more look...
Lady72nRob71 is offline
Old June 20th, 2011, 08:09 AM
Tom442's Avatar
Thanks Rob, I will look AGAIN! By the time I get this car put together, I may have all three books memorized.
Tom442 is offline
Old June 20th, 2011, 09:54 AM
allyolds68's Avatar
Tom,
I'm not sure if this is correct but mine goes from the hot on the horn relay, to the breaker on the firewall, to the switch.
I'm going to upgrade it with relays because 68-69 switches don't last long with the amp draw from the top motor
Mike
edit: Just looked again. Assembly Manual page 12-131
I just re-read the post....
If you haven't figured the wire colors by tonight I'll check for you. I can tell you the wire from the relay to the breaker and breaker to the block is black (yeah, I know, you'd think it was a ground but from the wiring diagram that appears to be correct)
allyolds68 is online now
Old January 20th, 2016, 09:21 AM
angelo68442convertible's Avatar
Mike Can you tell me what you used for the replacement convertible top relay and what ever else you replaced in that path?
angelo68442convertible is offline
Old January 20th, 2016, 10:33 AM
allyolds68's Avatar
I'm still using the original circuit breaker set up and haven't had a problem
I emailed you a couple wiring diagrams if you want to go that route
Old January 20th, 2016, 03:48 PM
Got that all taken care of. I installed a new breaker switch after work. all is well there. on to the dang mouldings. I need original part numbers for the following if anyone can assist . for the convertible. I need the original part numbers for the clips that hold down chrome around the back of the convertible top. I need the original part number for the 6 plastic door clips. the rest I have. anyone with original part numbers I wuld appreciate the help.
AZ442
July 26th, 2020 05:50 AM
pcard
May 14th, 2014 01:21 PM
stevengerard
September 18th, 2012 04:13 AM
JBrooks
Tech Editor's Desk
September 9th, 2012 03:25 PM
oldzy
September 10th, 2009 05:23 AM
Quick Reply: 68 442 Convertible Switch/Relay Wiring
