W-30 hood clearance
Old September 24th, 2010, 07:23 PM
toms vista's Avatar
W-30 hood clearance
I have a concern about hood clearance using an original W-30 steel frame hood , reproduction air cleaner , Q-jet carb. , and an Edelbrock Performer intake. Do I need to cut down the Performer INTAKE to get good seal to the hood or just trim down the foam seal ?
toms vista is offline
Old September 24th, 2010, 07:30 PM
stevengerard's Avatar
not sure why you would want to trim the intake, if the fit is that close just let the foam seal get squished
stevengerard is offline
Old September 24th, 2010, 08:33 PM
2blu442's Avatar
I've never tried it but over the years I've head repeatedly the performer will not fit under the OAI hood. Together with the carb and correct air cleaner top it's too tall. The O4B which is no longer being manufactured is an aluminum intake that will fit, but I've also been told the flow characteristics are not much better than the cast iron. It is much lighter though.... John
2blu442 is offline
oregontopcat
January 31st, 2014 06:31 PM
455cutlass1969
April 9th, 2012 11:13 AM
panther80
December 16th, 2011 08:57 PM
808olds
September 16th, 2010 11:38 PM
Insom
February 7th, 2010 08:58 PM
Quick Reply: W-30 hood clearance
