Why is my car not like my car?
Old June 8th, 2010, 08:47 PM
The Stickman's Avatar
Ok I have 2 Oldsmobile Custom Cruisers. Today I was working on both of them when we noticed that the 87 has the engine mounted slightly off center to the passenger side. Where my 84 has is mounted dead center. What's the deal?
The Stickman is offline
Old June 8th, 2010, 10:20 PM
svnt442's Avatar
Sounds like bad mouts to me. They should both be dead center.
svnt442 is offline
Old June 9th, 2010, 03:18 AM
Registered
Bluevista's Avatar
Did they change anything around the driveline to accomodate something? Older Mopars have the engine and rear off center, looks weird.
Bluevista is offline
Old June 9th, 2010, 09:26 AM
Destructor's Avatar
Many engines are mounted slightly off center, seems it was done for the steering linkage.
Destructor is offline
Old June 9th, 2010, 10:12 AM
GM Enthusiast
OLD SKL 69's Avatar
That doesn't sound right to me either. I would check the motor mounts too to make sure they aren't bad.
OLD SKL 69 is offline
Old June 9th, 2010, 10:18 AM
Same frame, same block, same motor mounts, same frame mounts. Stop reading header catalogs...
joe_padavano is offline
Old June 10th, 2010, 03:46 PM
I thgink you have it right. I looked today and the passenger side looks lower to me.
Old June 11th, 2010, 05:56 AM
Maybe the guys at the factory that assembled one of the cars was drunk...
Olds64 is offline
Old June 12th, 2010, 10:27 PM
Ok I checked out the mounts and they look good. I put a board under the oil pan and jacked up the engine and the car lifted not the engine so I think they are fine. BUT the mounts on the frame(clamshells) look higher on the drivers side. Are the holes in them sloted? I am going to try to loosen the bolts and level it out then tighen them back down.
Troys Toy 70
January 25th, 2012 07:22 PM
Dan K
December 13th, 2011 11:03 AM
droptopron
May 22nd, 2011 06:39 PM
The Stickman
May 21st, 2009 11:59 AM
TennesseeDelta
July 15th, 2006 07:30 PM
Quick Reply: Why is my car not like my car?
