Temperature sending unit
Old May 21st, 2010, 06:58 PM
Kace's Avatar
Greetings. Having a problem. Have a 68 convertible 350 2bbl. with A/C. Motor has the thermostatic vacuum valve in driver side port of intake. I dont see a temp. sensor unit in intake anywhere. There is a plug in port on pass side of intake. I bought one to put in but it is too big for hole. Where does that sucker go? I have a loose plug hanging next to oil sending unit which I'm sure is for temp sensor. Is there a smaller diameter temp sensor for that motor? Not comfortable running motor without it. Appreciate any response.
Kace is offline
Old May 22nd, 2010, 06:22 AM
Lady72nRob71's Avatar
Sounds like the vac valve is not supposed to be in that port - the temp sensor should be there instead.
The vac valve should be in the other port. Is this vac valve even supposed to be there? Is it original to the engine? A picture might help. If aftermarket, it might not be the right one and they stuck it there cause it did not fit in the other hole.
Just my guess.
Lady72nRob71 is offline
TheRuss
January 22nd, 2018 11:42 PM
68RocketAction
December 18th, 2014 11:19 AM
dynamic88
July 12th, 2009 08:15 AM
Pfiffle
February 21st, 2008 06:43 PM
boese1978
January 22nd, 2008 11:56 AM
Quick Reply: Temperature sending unit
