Repro dual snorkel air cleaner
I am seriously considering installing the ram air setup offered by the likes of the Partsplace. Any chance anyone here done the same on their 68 or 69?
I just did the majority of it this week on my 69. I'm waiting for the air cleaner to arrive so I can finish it.
I'm using the scoops Mike Siedlik makes which seem like a durable, flexible plastic. I do have a set of the Parts Place scoops which seem very fragile and brittle to me. In their defense I bought them off a guy who bought them when they first came out but never used them so maybe they've improved them by now? I'd be glad to tell you whatever you want to know about the install.
Partsplace quoted me $849.00 for everything included below.
(1968 - 1968 Cutlass/442) W-30 W-31 H/O APPEARANCE PACKAGE RAM AIR KIT - , 1 RAM AIR DUAL SNORKLE AIR CLEANER WITH CHROME LID, 1 PAIR OF CLOTH HOSES, 1 PAIR OF BUMPER SCOOPS, 1 PAIR OF HOSE BRACKETS, 1 SET OF STAINLESS MOLDINGS FOR SCOOPS, 1 PAIR OF SCOOP MOUNTING BRACKETS, 1 PAIR OF AIR CLEANER HOSE CLAMPS, 1 PAIR OF BUMPER SCOOP HOSE CLAMPS
I know, all that stuff adds up but it does look bad *** and is functional too. They usually have a deal on the whole package on ebay for $750 quite often. The thing I liked about Siedlik's scoops (besides the better quality) is his come ready to bolt on - brackets, bolts, instructions, chrome trim, everything. The Parts Place stuff has to be bought all seperate and adds up rapidly. Mike's are actually slightly cheaper when you add it all up. Plus, Mike is an Olds guy and loves these cars as much as we do. He's a good guy to deal with.
Can you hook me up with Siedliks?
His web site is down for some reason but here's a link to his ebay store. You should be able to contact him from there. If not let me know and I'll dig up his email address.
http://stores.ebay.com/Mikes442-and-Attic-Treasures
I like these better. They don't have the stock look some of you may be after. But they are functional and look cool. I am considering one and taking out my inner headlights and putting the inlets there.
http://www.ramairbox.com/
What I use to have cost me about $20. I picked up a cleaner from the junkyard for a buck and cut a hole in the base and welded a snorkle to the other side. Then I picked up some hose and put it on the car. Worked and looked great until I replaced it with a 70 version to go with the OAI hood I'm running now.
Then
Now
Then
Now
I have the single inlet airhat like this. What I thought of doing was putting a filter like pictured down inside the fender infront of the wheel. Using intercooler tubing to go from the filter to the airhat. Then box in the filter with a scoop leading from the bumper to the box
The hoses were long enough to go aorund the sides and come out in the bumper slots (see below)
I bought my whole set up from the Partsplace. Overall, I'm pretty happy with it. The flex hoses are dead on for the originals and I got the complete kit, so everything was there. Only draw back has been the hose-to-air cleaner clamps have since developed surface rust, but that almost makes it look original... Can't speak for the other companies, but mine worked out ok.
I've been thinking about one of these setups for my '68, but will have to see how the budget shakes out toward the end of its resto....
Good info! I didn't know there was another source. I would rather support an Olds guy than have to wrangle with TPP...
Has anyone ever compared one of these (either Mike Siedlik's or TPP's) to an original for fit/finish/accuracy ? I agree they're expensive, but the OAI setup looks so nice and it'd make the decision easier knowing that they look like they're supposed to....
I just did the majority of it this week on my 69. ....
I'm using the scoops Mike Siedlik makes which seem like a durable, flexible plastic. ...I liked about Siedlik's scoops (besides the better quality) is his come ready to bolt on - brackets, bolts, instructions, chrome trim, everything. The Parts Place stuff has to be bought all seperate and adds up rapidly. Mike's are actually slightly cheaper when you add it all up. Plus, Mike is an Olds guy and loves these cars as much as we do. He's a good guy to deal with..
Hi there, I have a question for 442much, I like your pics. My 68 has a similar air cleaner with dual snorkels like yours and I am planning to do the exact same thing you have done with the flex tubing. Do you find a difference with this set up? Am I correct that you built this "dual" out of two seperate cleaners?? K&N filter also going into mine. I have family and friends in Sherwood Park, cool!
455rkt,
I cannot say you can't feel a differnece from the "seat of the pants" (nor can you on any air induction system) and the system (under bumper style) is not really a "ram air" set up- more akin to Cowl Induction, where, it allows the engine to only pull outside (cooler/dense) air, therefore your motor is producing more HP. The level of HP generated depends on speeds, etc., but it is a performance benefit, just not one you may notice much. The "cool factor" you'll notice immediately !
4speedBench, thanks for the input. Answer me this if you can. The dual snorkel air cleaner on my 455 is great, BUT i don't often see them on other 455's, do you know if it was an option, or is my air cleaner not original (i dont care). In my 68 service manual there is a birds eye schematic of the frame and engine that shows the dual snorkel air cleaner. Thoughts?
#31
It's two air breathers made into one. The picture I used above is an older one. About two weeks before I made the change over to the OAI system with the W25 hood, I found some plastic snorkle ends that would work in place of the stainless worm clamp. It looks more authentic and I like the looks. I also found plastic ends for the ends of the hose at the bumper outlets. Don't have pictures of that since I made the change over only a short time after finding the plastic pieces. The whole deal was about $20.
The set up is not original for my year, but is an Oldsmobile idea used on an Oldsmobile car, and that's OK with me.
#32
I added the OAI set-up on my 69, I bought the air cleaner housing at a chebby swap meet (the camaro and chevelle guys didn't know what it was!) I bought the rest of the parts needed aftermarket. Looks good, I love the comments at the car shows and drag strip, most people outside the Olds community have no idea what the OAI system is.
#33
4-speed, I just purchased this kit from the Partsplace. Do you have any tips or pictures on the exact location you used to mount the scoops?
Any advice would be appreciated.
#35
Nilsson,
Hope these shots help. I studied two original w-30 cars to get my reference points. One of the key indicators was that the 4" holes appear to align perfectly with the center bolt of the inner fender structure along the sides of the radiator support. Hopefully the picture below helps with my attempt to describe. The brackets that actually attach to the scoops was the hardest part...a bit of trial error for me. To do correctly, you should buy the w-30 specific fender to frame braces (I've seen for $75.00) that help clear the scoops. I did not buy these and was able work them into place and they look correct standing in front of the car. So it's your call. Either way, take your time on the scoop brackets. You'll be able to test fit what you need to do once the 4" holes are cut. BTW, a 4" hole circular hole cutter makes this part take about 30 seconds. They were actually cut more crudely from the factory.
Good luck!
Good luck!
#36
You are good, if you get bored and need something to do a picture of the scoops from underneath (specifically the brackets) would be most excellent although not required.
I really appreciate the info and pictures. This gives me a great starting point which is 90 % of the battle.
Again thank you very much.
#40
