1969 442
Old December 10th, 2009, 05:39 PM
ziff396's Avatar
1969 442
I need a fast vin decode for a 69 442 4 sp. on craigslist. Maybe I need 2 cars??
This will go fast.
VIN#344879m165991
3.91 rear.
That is all I know at this time.
ziff396 is offline
Old December 10th, 2009, 05:49 PM
2blu442's Avatar
You can't have too many toys
The vin identifies it as a 442 and yes the 3.91 rear end gears (should be a posi as well) was an option. If factory the housing should have a TO or T3 code stamped in it. The T3 would be if the car came factory with disc brakes.
If the price is right check it out for sure. When you get more details post them if you'd like to get more feedback on the car. John
2blu442 is offline
Old December 10th, 2009, 06:05 PM
jaunty75's Avatar
Every Olds enthusiast should keep this site near the top of his/her bookmark list:
http://www.v8cars.hu/oldsvin/decode.php
As 2blu442 says, this car is a 1969 442 2-door Holiday Hardtop built at Lansing.
jaunty75 is offline
Old December 11th, 2009, 04:26 AM
3= Oldsmobile
44= 442
87=2 door Holiday coupe
9=69
M=Lansing Mich.
The last 6 digets are the production numbers beginning w/100001
Jamesbo is offline
Old December 11th, 2009, 07:57 AM
ziff396's Avatar
The car has a rebuilt 455 in it with 600 miles on it. (Not the original 400). Rebuilt 4 speed and rear end. Decent interior. Good frame. From what he says, it probably needs floor and trunk work along with quarters. I could do all the labor, metal, body, and paint myself. I may look at it tomorrow. He is asking $5900.00 for it.
ziff396 is offline
Old December 11th, 2009, 08:27 AM
...From what he says...
Which is usually overly optimistic, in my experience.
...it probably needs floor and trunk work along with quarters.
The only repro quarters are the ill-fitting Chinesium partial quarters.
Just be very careful to add up all the sheet metal you'll be buying. Look very closely at the pinchweld areas for rust. It's almost always less expensive in the long run to buy a more solid, complete car.
DO NOT ask me how I know this...
joe_padavano is offline
Old December 11th, 2009, 08:45 AM
ziff396's Avatar
Thanks Joe. That was kinda along the same lines I was thinking. I may still take a look at it, as it is only about an hour away.
ziff396 is offline
crystal59
July 6th, 2023 04:39 PM
Gearhead442
February 2nd, 2020 11:56 AM
halfmoontrail
August 31st, 2013 09:05 PM
62radarlove
January 19th, 2012 09:05 PM
mcutlass1969
Drivetrain/Differentials
February 12th, 2008 08:59 AM
Quick Reply: 1969 442
