73 to 77 versus 69 to 72 tilt column
Old May 15th, 2019, 07:20 PM
brandon reynolds's Avatar
Just wondering what’s the difference between the two groups of columns. I have access to a 73 to 77, I am wondering what it would take to put in the 71. Thanks advance for any info Brandon
brandon reynolds is offline
Old May 16th, 2019, 03:37 AM
It’s a bolt in. The tilt column in my 69 came from a 75 Cutlass. I swapped the lock cylinder and hazard switch button to keep the 69 look. My column has the dimmer switch on the turn signal lever, if your column has that feature make sure you get the jumper harness or you will need to make your own. You can take the column dimmer switch one step further and add the “flash to pass” by installing a dimmer switch from a 95 Cadillac Fleetwood. You need to add one wire (a constant power feed, the red wire at the headlight switch is ideal) to the dimmer switch connector. Once this is done, pull the turn signal lever towards you, the high beams will come on, regardless if the headlights are on. Release the lever. The lights go out. Pretty slick, and a easy 15 dollar upgrade.
matt69olds is offline
Old May 16th, 2019, 04:00 AM
toymobile's Avatar
I have a 73-77 Floor shift TILT for sale if anyone is interested, $175. Plus the ride.
New turn signal switch, lock cyl. removed
toymobile is offline
Old May 16th, 2019, 04:05 AM
matt can i just not use the dimmer switch on the column and use my floor mounted dimmer and put the regular 71 turn signal lever in? thanks for the help brandon
Old May 16th, 2019, 09:14 AM
I think you could swap turn signal levers, my column came out of a car with cruise. I used the “set” button as a trigger for my nitrous purge. Now that I have a actual cruise control setup on the car, the cruise lever is used as intended.
Old May 16th, 2019, 09:17 AM
Now that I’m thinking about it, the turn signal lever won’t swap. On a column with no dimmer switch, the lever screws directly to the turn signal switch. On a column with a dimmer switch, there is an extra linkage. It’s been a while since I have had them both apart to compare
Old May 17th, 2019, 08:30 AM
Majic Jack's Avatar
How is the back dive linkage handled between these two different models?
Majic Jack is offline
Old May 17th, 2019, 08:50 AM
toymobile's Avatar
The back drive can be adjusted to the different angle between the 69-72 as compared to the 73-77
Philfinley
August 17th, 2019 07:52 PM
toymobile
June 18th, 2018 05:50 AM
Stephen0523
September 21st, 2016 09:12 AM
OLDSmobility
October 3rd, 2010 12:04 PM
phill_ratrodv8
December 8th, 2008 08:13 PM
Quick Reply: 73 to 77 versus 69 to 72 tilt column
