Replacement RADIATOR
Old March 31st, 2019, 11:07 AM
Zacc's Avatar
Spring surprise - Looks like a leak in my 72 Cutlass supreme radiator. Whats the way to go with a replacement? Aluminum 4 row?
I have 455 no a/c, no shroud. Would going to 3 to 4 row cause any direct fit problems? Does Summit make a good radiator?
Zacc
Zacc is offline
Old March 31st, 2019, 12:52 PM
OLDSter Ralph's Avatar
Whats wrong with fixing what you have ? It can be repaired and pressure tested. It will fit back exactly.
OLDSter Ralph is offline
Old March 31st, 2019, 06:00 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Look for a good radiator shop in your area and get it recored. If the tanks are shot they should be able to source the correct rad for you. Do a good flush of the system before reinstallation no matter which way you go. Good time for belts hoses T-stat etc...
droldsmorland is offline
Old March 31st, 2019, 07:02 PM
Hookers under Hood
76olds's Avatar
Zacc, their are many choices if your looking for a decent aluminium rad. I purchased and stand behind the Be-Cool, 2 row with 1" tubes made in the U.S.A aluminium rad. A little more money than others, however, keeping the car cool for many years was worth the extra cost for me.
As others mentioned, If you can find a local rad shop that still does repairs and re-cores, a 3 row copper core will cool your car well enough, no need for a 4 row unless you are towing a trailer or boat IMO.
Lots of options depending on price.
X2 on a good flush before removal, New, T-stat, hoses, rad cap and belts are always a good idea at this point.
76olds is offline
Old April 1st, 2019, 07:12 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I personally like cooling overkill, especially on a 403 or 455. I am planning on this one.
https://www.coldcaseradiators.com/pr...mance-radiator
olds 307 and 403 is offline
Old April 1st, 2019, 08:42 PM
Coldcase is a new entry in the Abody world. Good reviews so far.
oldcutlass is offline
Old April 2nd, 2019, 05:04 AM
83hurstguy's Avatar
DeWitt's makes a very nice piece as well. Two row aluminum, 1" tubes, looks pretty stock.
83hurstguy is offline
72442conv
May 14th, 2019 03:21 AM
SanTan Devil
May 7th, 2019 11:27 AM
bfaucher
July 17th, 2018 09:39 AM
The Flash
Ninety-Eight
August 6th, 2017 09:01 AM
jpc647
January 6th, 2017 07:44 AM
Quick Reply: Replacement RADIATOR
