Th350 kick down cable?
Old March 24th, 2019, 05:48 PM
Platinum69's Avatar
Where does the kickdown cable connect for a th350 transmission? I believe it is the carberator, not sure. The original th400 cable connected at gas pedal? Thanks
Platinum69 is offline
Old March 24th, 2019, 06:06 PM
svnt442's Avatar
TH400 has an electric kickdown. TH350 on the 69-72 cars goes to the pedal. 73 and up to the carburetor.
svnt442 is offline
Old March 25th, 2019, 07:31 AM
To add to Randy's response, the accelerator pedal for the 69-72 cars with TH350 is different from those used with other transmissions. The TH350 pedal has an extra tab for the kickdown cable. This tab conflicts with the electric switch used on the TH400 and Jetaway, so you can't mix them.
joe_padavano is offline
Old March 25th, 2019, 08:42 AM
Now my .02, if your not a stickler for originality, you can install a universal carburetor/ manifold mounted kickdown cable.
oldcutlass is online now
Old March 25th, 2019, 08:58 AM
Platinum69's Avatar
So then, it's a 69 car with a 73 motor and transmission it should go to carburetor?
Old March 25th, 2019, 09:11 AM
It should go to wherever you want. The factory style routing to the accelerator pedal is completely independent of the engine. It does require the correct accelerator pedal. If you choose instead to run it to the carb, does your carb have the correct feature on the throttle arm to pull the cable correctly?
oldscutlass74
December 5th, 2018 09:32 PM
Crockett 999
April 27th, 2015 07:57 AM
bigbrother
17
March 11th, 2012 06:45 PM
Beeks69
September 23rd, 2011 07:15 AM
archerbob
September 12th, 2011 01:29 PM
Quick Reply: Th350 kick down cable?
