To flush or not to flush trany
Old March 21st, 2019, 01:25 PM
442fanatic's Avatar
Spring is here and been looking at my work car, an 04 Buick Regal, with the durable 3800. 258k miles and climbing. Checked the transmission oil, and it is more of a brownish color than the nice red.
The car was my wife's, she bought it with 80k on it. Dealer serviced since, with exception last few years. I have not called them to inquire if it has ever been flushed...
Years back I had a 91/92 cutlass that had bad trans oil, but with lower miles. I pulled the pan, changed the filter, new oil. And in a few hundred miles the transmission went, wasn't shifting...
From my past experience, not a good idea of flushing this transmission and risk having it go.. What are your all thoughts. Work car, goes 20 miles a day, occasional trip to nearest local town for groceries...
442fanatic is offline
Old March 21st, 2019, 02:58 PM
tcolt's Avatar
It would depend. If I knew the transmission was still pretty tight and I knew it operated with no problems and I wanted to keep the car for a long time, I would chain the fluid and filter. I don't think I would flush it with anything because that can dislodge more particles than you'd like. If I only was going to keep the car for a few more years and it was already doing weird things I'd probably leave it alone or maybe just change the fluid and see how much stuff was in the pan.
tcolt is offline
Old March 21st, 2019, 03:28 PM
Sugar Bear's Avatar
This is an aged old question that doesn't have an exact answer. I've had transmission only pros say leave it alone. That is what I'd do this late in the game. If it shows a problem I'd change the filter and fluid. I definitely would not do a "flush" of any type unless a problem already existed and a fluid and filter only didn't help.
Good luck!!!
Sugar Bear is offline
Old March 21st, 2019, 03:57 PM
This is getting into apocryphal knowledge here, but, this is what I know.
1. Never, ever flush. This is a dumb thing always.
2. Ideally, one should service at prescribed intervals. If the thing has a drain plug, a fluid swap is often enough, especially if the filter is just a metal screen.
3. If it has high miles, and is ok, often times "leave it alone till it dies" is good advice.
If it has a drain plug, I would drain the fluid, when car is still kind of warm, let it drain for a good hour, put the plug in, then put new fluid of the same type of the same amount back in.
Koda is offline
Old March 21st, 2019, 07:38 PM
Its about due for an overhaul. Generally brown fluid means the transmission is getting hot due to worn components. Don't waste your money on a flush. You may or may not get by for a while longer with a fluid and filter change.
oldcutlass is online now
Old March 22nd, 2019, 04:17 AM
If you decide to flush it here's a good video:
I had a 93 Buick LeSabre with the same transmission, a 4T60E. The transmission started to die around 150k miles so I sold it before it got bad. It really is a roll of the dice flushing the transmission. You already have over 200k miles on the car. If you flush the transmission I would at least put some "slick shift" in it at the same time.
Olds64 is online now
Old March 23rd, 2019, 06:50 AM
'87 Delta 88 Royale
rustyroger's Avatar
Drain as much as you can replace the filter, otherwise leave it alone.
Do budget for a transmission rebuild sometime soon unless the cost of overhauling the transmission is more than the car is worth to you.
if so drive it until it dies,
if you want to keep the car I suggest when you have the funds get the transmission overhauled when it suits you. Much better than stranded on the highway when you need transport.
Get it done properly and the transmission will outlast the rest of the car.
Roger.
rustyroger is offline
Old March 23rd, 2019, 01:04 PM
In my opinion, there is nothing that can be hurt from changing the filter and fluid. As someone who has spent many years in the transmission industry, in my experience most people neglect the filter and fluid until there is a problem. Transmission service is looked at as a “might as well try it and hope for the best”, by then the damage is done. Fresh filter and fluids will do nothing for damaged clutches, bands, and other parts.
I change the fluid and filter and adjust the bands on my 06 diesel Ram about every 20-25k miles, I’m about to turn 200k on the original factory trans. There is never more than a fine layer of debris in the pan. I do tow with this truck, and it does have some engine upgrades. Still works like new.
As for fluid appearance, brown just means the fluid is nearing the end of its life. When the fluid is really dark and smells burnt, that’s when things are starting to fail. I still wouldn’t hesitate to change the fluid under those conditions.
matt69olds is offline
Old March 25th, 2019, 06:34 AM
Ozzie's Avatar
I'd skip the flush. Replace the fluid with the correct type. Drain the torque converter if possible. Change the filter.
Ozzie is offline
Old March 25th, 2019, 06:44 AM
Yeah, but those Cummins diesels are missing 2 cylinders so how much wear can the transmission get?
Really though, this is all good advice. Let us know what you do.
Old March 25th, 2019, 07:44 AM
blakes7's Avatar
I used to change my fluid, but it seems like overkill when the fluid I drain out is just as clean and fresh as the new fluid I pour in, and always finding a pretty clean pan. This is with 30,000 miles on it, never towing anything. So I'm going to try leaving it in longer to see what happens. I'm guessing that if I leave it in there for 60,000 it'll still be clean, or be barely changed. Maybe I'll change it then. By the way, I'm talking about two 2007 Chevys.
I've heard opinions ranging from don't change fluids, just get a new car every so often, to if the fluid is turning from red/pink then damage is already done so forgetaboutit. Since I like a well oiled machine, I like to change fluids periodically. I guess I just need to find the right interval for modern transmissions. By the way, a family member has a 2012 Jeep Patriot, bought new, adult driven, now has 48,000 miles on it, CVT transmission fluid is still clean. What do you think about changing the fluid in those, and how often? I can't remember what the owner's manual said, I think it might have been a 60k or 100k interval. The Jeep is in central Florida.
blakes7 is offline
Old March 25th, 2019, 08:58 PM
missing 2 cylinders huh? I have run the truck a few times at the track, 14:30 for a basically stock 7200lbs 4x4 truck is pretty respectable in my opinion. I remember when I swapped the 455 in my car back in the late 80s I was pleased with the 14:00, and annoyed I was so close to the 13s. Other than a programmer, shift kit, and tone wheel mod, stock. There is plenty of potential in the 5.9 Cummins.
As for the CVT trans, I know nothing about them. Once again, I don’t think there is anything wrong with routine fluid and filter changes. If nothing else, you will have a baseline to examine wear.
Old March 25th, 2019, 09:14 PM
Rocket Renegade!
I don't think anybody said anything about CVT transmissions.
BangScreech4-4-2 is offline
Old March 26th, 2019, 05:09 AM
Oh yeah!
Old March 26th, 2019, 08:16 PM
How do you post and highlight certain parts of conversations? Anyway, the CVT trans was mentioned in a previous post.
Old March 27th, 2019, 10:56 AM
Rocket Renegade!
Just quote it and use the cursor to edit it down to the part you want to highlight.
Yeah, I found the post with CVT reference in it. Still don't know how blakes7 thought that would be relevant to the topic at hand.
Old March 27th, 2019, 02:45 PM
blakes7's Avatar
Since the man I quoted was a transmission expert, or at the very least knows a heck of a lot more than I do, I was asking his opinion.
blakes7 is offline
Old March 29th, 2019, 08:35 AM
Schurkey's Avatar
I never bother to just "pan dump" fluid on my own vehicles.
Oh, sure...it starts with a pan dump and filter change. Reinstall the pan. Then drop the cooler tube on the return side of the cooler. Add fluid to the trans pan, install a short "temporary" tube at the cooler, directed into a drain pan. Start engine, dump more fluid down the dipstick tube until fluid blowing into the drain pan is clean. Shut off engine. Reconnect trans cooler tube. Start engine, top off fluid as needed.
Done.
If a fluid change "harms" the trans, the trans was on it's last legs anyway. Nothing to fear.
Schurkey is offline
jpatfarrell
15
November 24th, 2018 03:30 PM
Mak
18
October 20th, 2011 06:46 PM
NorTown Olds
October 4th, 2011 01:31 AM
mike623
September 7th, 2010 09:48 AM
cola
February 16th, 2008 10:27 AM
Quick Reply: To flush or not to flush trany
