Choice of Oil for older 50's motors
Old March 16th, 2019, 07:09 PM
johnreb49's Avatar
I have a 54 88 with the 324
Which oil is the best ?
johnreb49 is offline
Old March 16th, 2019, 08:01 PM
Ozzie's Avatar
You'll likely get a lot of answers on this question. I have a '55 with essentially the same engine. It's hard to say which is best. Many have different opinions on just viscosity. If you like to read and have a bit of time available, you could read:
https://540ratblog.wordpress.com/201...-test-ranking/
Ozzie is offline
Old March 16th, 2019, 08:23 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Many of us use Valvoline VR1 Racing Oil which is high in zinc content. You have to do that or add ZDDP to get the zinc. Without zinc you will wind up with a flat camshaft I think Shell Rotella works also but am not sure.
redoldsman is online now
Old March 17th, 2019, 03:55 AM
same but different
don71's Avatar
Good looking car. I'll second the Valvoline VR1 oil.
don71 is offline
Old March 17th, 2019, 07:46 AM
Tedd Thompson's Avatar
I use the Rotella 15/40 for the zddp and the high detergent, keeps my lifter free and quiet. But as mentioned by Glenn the options are endless as long as the oil has the correct zddp.
I had issues with full synthetic oils weeping/leaking through my cork gaskets so I'm using full dino products now. You may or may not have this issue especially if you have neoprene top and bottom on your engine..... Tedd
Tedd Thompson is online now
Old March 17th, 2019, 04:40 PM
I used to link to the 540rat blog. Now there is so much BS in it its hard to follow. I use VR1 10x30 in my car also.
oldcutlass is online now
Old March 18th, 2019, 06:19 PM
Any modern oil will be superior to anything available 20 years ago, and oil from 20 years ago would be better than what that car had originally. If it’s a stock well worn engine, I don’t think the zinc content would matter much. The spring pressure and well established wear pattern wouldn’t require much zinc to keep things happy. Having said that, if the engine is fresh, or prefer to play it safe, Valvoline VR1 is hard to beat.
matt69olds is offline
Old March 18th, 2019, 06:41 PM
redoldsman's Avatar
Why would you even take a chance and not use oil with high zinc? Not worth the risk.
Dan Wirth
June 17th, 2019 12:08 PM
GlennC
January 20th, 2019 10:11 AM
ART T
October 29th, 2016 03:16 PM
scooter123
March 5th, 2014 11:23 AM
olds67
December 5th, 2009 01:11 PM
Quick Reply: Choice of Oil for older 50's motors
