Finally finished - 1968 Cutlass Supreme W-31 tribute
Old March 10th, 2019, 09:02 AM
Gearhead
Jon442's Avatar
My first car was a 1969 Cutlass S convertible in Saffron Yellow. In late 2017, I decided to try to find one like it, and found one right away on eBay. But the $70,000 asking price was much more than I wanted to pay. So I expanded my search to all '68 and '69 Cutlasses. I found this car, but initially passed on it due to the color change. But the more I looked, the more I kept going back to this car. The color really grabbed me and I thought the car had a lot of eye appeal. I contacted the seller and he assured me that the repaint was done very well. So I ended up buying it. It's a very nice car, very clean with no rust, and Canadian built. It has 48,000 miles. Once I got it home and saw how nice it was and verified the seller's claim that the paint job was done correctly, and decided to keep it, I started on a plan. Since the color and hood had been changed, I wasn't too concerned about keeping it completely correct and decided to have a little fun with it.
I believe the color to be very similar to a Pontiac color called Aleutian Blue.
Oldsmobile offered the W-31 option on the Cutlass Supreme in 1968, but it kept the high-compression 4-bbl engine that was standard in the Supreme instead of the W-31 engine. I assume this was a customer satisfaction measure, meant to keep the rough-idling W-31 engine from annoying Supreme buyers. I decided to go with the W-31 style engine. We pulled the heads, had them machined for large valves, and installed a little tamer and more modern version of the W-31 cam. It still has a rough idle, although not quite as rough as a real W-31. This enabled us to keep the automatic transmission and add air conditioning and power disc brakes. We also added a set of aftermarket high performance exhaust manifolds and replaced the carb with FiTech fuel injection.
The original Jetaway went away in favor of a built 200R4 with a 2200 rpm stall converter. We swapped the rear gears to 3.73 with anti-spin.
The interior was completely redone in the original parchment color. We added aftermarket guages and a tach to the two outboard pods in the instrument panel.
We added a rear sway bar and had the steering box converted to 10:1 ratio, but otherwise left the suspension alone. Because of the front disc brakes, we went with 15x7 SS1s in front and 15x8 in the rear for a little more rubber.
I've only been able to put a few miles on the car so far, and we still have some fine-tuning to do on the FiTech. But the car drives great and is a blast to drive. It turns about 2800 RPM at 70 mph. I'm looking forward to spring and some driving weather!
Jon442 is offline
Old March 10th, 2019, 09:14 AM
JohnnyBs68S's Avatar
Sweet 68, I'm following in your footsteps, all that is left for me is the bullet under the hood.. Do you plan on taking it to the dragstrip?
JohnnyBs68S is offline
Old March 11th, 2019, 09:50 AM
allyolds68's Avatar
That's a nice one. I think that's the color of my first 68 Supreme.
May I suggest the Ram Rod 350 decals on the fenders.....
allyolds68 is offline
Old March 11th, 2019, 10:27 AM
taa442's Avatar
Great car!Like the stance,color,wheel tire combo!Nice clip of back of car running.What a view.Always liked the 68 for the thin horizontal tailights.What are the tire sizes and brand? I have a 68 myself so I guess I am biassed. Tim
taa442 is offline
Old March 11th, 2019, 10:32 AM
Sweet looking ride.
oldcutlass is online now
Old March 11th, 2019, 10:34 AM
71 & 72,now I want a 68
w-30dreamin's Avatar
Great job,this car turned out very beautiful!
w-30dreamin is offline
Old March 11th, 2019, 11:51 AM
Gearhead
Jon442's Avatar
Thanks! The color/wheel/tire/interior combination really caught my eye. The tires are Diamond Back radials. I've used them several times over the years and have always been happy with their tires. They can make any tire style you want. My tires are 235/60/15 front and 255/60/15 rear.
Jon442 is offline
Old March 11th, 2019, 11:54 AM
Gearhead
Jon442's Avatar
To me, that would be up-badging. And besides, I want to keep a stealthy look.
Jon442 is offline
Old March 11th, 2019, 05:02 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Absolutely beautiful car! Check your speedometer, your rpm is about 600 rpm high unless you are running a non lock up converter.
olds 307 and 403 is online now
Old March 11th, 2019, 05:12 PM
68conv455's Avatar
Beautiful car. Enjoy.
Best color on a 68 by the way. Is the interior pearl like mine or white.
68conv455 is offline
Old March 11th, 2019, 06:45 PM
Gearhead
Jon442's Avatar
I checked the speedo with an app on my phone, it's within a mile or two per hour of being accurate. The trans is a performance-built trans, so I'm assuming it doesn't have a lock-up converter.
Jon442 is offline
Old March 11th, 2019, 06:46 PM
Gearhead
Jon442's Avatar
The interior is parchment, kind of an off-white pearl.
Jon442 is offline
Old March 11th, 2019, 07:19 PM
Aron Nance's Avatar
Really a beautiful ride!
Aron Nance is offline
Old March 13th, 2019, 06:26 PM
old80cs's Avatar
Beautiful 68', that's my favorite model year Olds.
old80cs is offline
Old March 14th, 2019, 06:53 AM
rob1960's Avatar
Nice job Jon! Looks & sounds great!!!
rob1960 is offline
Old March 14th, 2019, 07:07 AM
Looks very similar to the Pearl interior in my 70S. I like it better than white, pretty and more forgiving with dirt.
Dpclassiccarz
March 15th, 2019 09:57 PM
Jon442
February 8th, 2019 05:05 PM
OldsAl
July 16th, 2017 10:50 AM
66-3X2 442
July 29th, 2015 02:13 PM
OldCar_Mechanic
September 21st, 2010 04:16 PM
Quick Reply: Finally finished - 1968 Cutlass Supreme W-31 tribute
