82 olds parking brake cable install
Old March 8th, 2019, 09:42 AM
76CUTLASSTTOP's Avatar
Hi everyone. I have a 1982 Oldsmobile Custom Cruiser Station Wagon. The parking brake cable from the pedal has seized. I bought a replacement. Does the left front fender have to come off in order to remove the cable?. The only thing holding me up is the rubber grommet that snaps into the sheet metal at the fire wall. Can't see it from the outside due to the fender being over top of it. Any help would be appreciated.
76CUTLASSTTOP is offline
Old March 8th, 2019, 09:52 AM
Did you remove the fender well? Removing it should give you easy access to the driver's side of the firewall.
Olds64 is offline
Old March 8th, 2019, 10:05 AM
Olds64: Thanks for the reply.....I started to remove the metal fender well but several fasteners are seized.....looks like the fender has to come off first before I can get the fender well out.
Old March 8th, 2019, 10:51 AM
Well, you might consider using your favorite lubricant (PB Blaster, WD-40, Kroil penetrating oil) on the fasteners; as well as, the existing E brake cable. You might be able to free it and not need a replacement.
Olds64 is offline
don71
December 20th, 2018 10:30 AM
sheltonoil
Brakes/Hydraulic Systems
May 10th, 2017 08:13 PM
Dead Reckon
16
April 6th, 2015 12:48 PM
69'442
March 30th, 2013 07:12 PM
GoodOldsGuyDougie
November 22nd, 2010 08:07 AM
Quick Reply: 82 olds parking brake cable install
