TH425 used in Vector W8?
Old March 7th, 2019, 06:43 AM
So, I just got my latest issue of the Hagerty magazine yesterday. Usually I just flip through them and put them in the break room at work. This month they had an article about the Vector W8. Has anyone else read it?
The article mentions that the Vector W8 used a "slushbox" TH425 out of an Olds Toronado with upgraded internals. Apparently, the TH425 wasn't a good choice for the Vector and resulted in high failure rates. Frankly, I was surprised to read this about the most durable automatic transaxle GM made (maybe I'm a biased reader). True, the TH425 was probably a poor choice for a supercar, but I thought it would be easy to build a TH400/TH425 to survive 600+ HP... I guess the problem was due to spinning the TH425 fast enough to move the car to 150+ mph. I doubt there are many Oldsmobiles that ACTUALLY drive that fast.
Olds64 is offline
Old March 7th, 2019, 07:05 AM
The real problem (well aside from the fact that Gerry Weigert was more of a huckster than Delorean...) is that they modified the TH425 to mount the engine transversely. This required a custom right angle drive between the trans output shaft and the differential. You can see the cover for the TH425 chain drive in this drawing.
joe_padavano is offline
Old March 7th, 2019, 08:08 AM
I was surprised that a TH425 and small block Chevy engine were used in the Vector. The article indicated that Weigert wanted the Vector to be hi-tech and groundbreaking. A TH425 and SBC engine are neither. I would expect them to be used in an episode of Roakill Garage not in a $200k+ supercar.
Olds64 is offline
Old March 7th, 2019, 08:16 AM
Keep in mind that this car was developed in the 1980s. It was intended to be all US-built. There were no "higher tech" options then.
Old March 7th, 2019, 10:42 AM
hurst68olds's Avatar
the Vector W2 "concept car" dates from '78 - the W8 production cars finally came out for the '90 model year
for '78 it would've been groundbreaking for a US car, by comparison Countach debuted in 1974 and was in production thru '89
https://en.wikipedia.org/wiki/Vector_W2
hurst68olds is offline
Old March 7th, 2019, 10:48 AM
since it was mentioned - DeLorean
prototype was around in 1976 & made production 1981-'83
Old March 7th, 2019, 10:53 AM
Period magazine articles claim that Vector development started in 1971.
Old March 7th, 2019, 11:07 AM
so, the Ford engined - Italian built Panteras were in Lincoln-Mercury showrooms when the thought process was conceived
Old March 7th, 2019, 11:21 AM
More likely the transverse-engined Lamborghini Miura, first seen in 1966, was the real inspiration.
Old March 7th, 2019, 11:28 AM
Talking
this should've been part of the mindset, instead of the Chevy, then it would've been "SUPER"
Old March 7th, 2019, 11:54 AM
Yeah, but unfortunately by the time the Vector actually made it to a running, driving vehicle, the Olds 455 was out of production.
Old March 7th, 2019, 11:57 AM
I agree. Even if it hadn't been an Oldsmobile engine there were plenty of "experimental" engines developed by the big 3 before the 80s that would have been much more fitting for a supercar than a run-of-the-mill SBC. Also, a 3 speed automatic is about as "UNsuper" as you can get. Why do you think everybody and his brother wants a 4 speed manual in their Cutlass?
Olds64 is offline
Old March 7th, 2019, 04:08 PM
Are those giant silver things out front blowoff valves?
Koda is online now
Old March 12th, 2019, 09:29 PM
Schurkey's Avatar
Which of the Big 3 companies had investment money in the Vector?
Schurkey is offline
Old March 12th, 2019, 11:47 PM
svnt442's Avatar
I think they are external waste gates.
svnt442 is offline
Wykydtron
September 3rd, 2019 05:48 AM
Rocketowner
January 29th, 2017 04:06 AM
kartmaster
September 22nd, 2013 08:58 PM
Schober Motorsports
December 10th, 2010 05:29 PM
gmackner
July 16th, 2007 09:08 AM
Quick Reply: TH425 used in Vector W8?
