Tilt column
Old February 12th, 2019, 05:00 PM
brandon reynolds's Avatar
Tilt column
Guy says it olds does anyone know what year this is thanks Brandon
brandon reynolds is offline
Old February 12th, 2019, 05:09 PM
Rocketbrian's Avatar
The levers are from 71 and up Oldsmobile, but the bracket/plate that fastens to the inside firewall is not from a 70-72 A body. So most likely 73-77 if from an A body. I don't know when they went to the high beam switch on the column. Others will probably be able to give you more info.
Rocketbrian is offline
Old February 12th, 2019, 05:24 PM
The column in my 69 came from a 75 Olds Cutlass. Swap the floor mounting plate, disconnect the dimmer switch on the floor, and plug in the dimmer jumper. I swapped the lock cylinder and hazard light button to the 69 parts for a more original look. Other than that, it’s a easy swap
matt69olds is online now
toymobile
August 8th, 2020 11:29 AM
brandon reynolds
March 15th, 2019 02:06 AM
Cincinnati Rick
November 13th, 2018 03:26 PM
oldgold
March 25th, 2013 07:31 AM
andyman
July 25th, 2012 03:09 PM
Quick Reply: Tilt column
