Can these still be purchased or do I need to make one?
This is the spindle off my 71' Cutlass. Looking for this gasket, any ideas? I have the material to make them. This one is broken and has rust stuck to it. I looked in the Chassis section but didn't see anything.
That looks like the gasket that goes between the Backing Plate and Steering Knuckle. You can get it from Inline Tube.
https://www.inlinetube.com/products/INL10443
Note that it's just an anti-rattle part, so cutting a disc out of a fiber gasket material will work quite well. Dimensions aren't critical. Unless you're going for factory-correct, then look into a supplier.
Oldssupreme
July 27th, 2016 03:56 AM
oldzy
Drivetrain/Differentials
September 27th, 2010 05:49 AM
