maybe solved the repro "grille molding" fitment issue?
Old January 26th, 2019, 04:58 PM
chip-powell's Avatar
After seeing how mine turned out, a friend asked me to redo the grille for his '71 cutlass. His moldings were trashed so he ordered a new set from OPGI. From reading previous threads we were all set to cut off the tabs and attach them through either screws or double sided tape.
To our surprise, they fit perfectly. The tabs lined up exactly with the predrilled holes. The only thing that I can figure is that his grilles were not repros, but the original metal '71 cutlass' not the plastic 442's.
Could that have been the problem all along for everyone? Are the repop moldings on the market designed more for the Cutlass and not for the 442 grilles?
I plan to continue the experiment. The moldings on my '71 Supreme are in pretty good, but not great shape. I'm going to order a set for myself and see if the tabs line up for mine also.
We'll just have to wait and see.
chip-powell is offline
Old January 26th, 2019, 05:02 PM
71 & 72,now I want a 68
w-30dreamin's Avatar
I would be interested in knowing for sure,I need a set of the moldings for my oem plastic 71 Cutlass S grills.
When you say metal 71 Cutlass grills,I'll assume your referring to the Supreme grills.
w-30dreamin is offline
Old January 26th, 2019, 06:59 PM
Yes I meant the Supremes. Sorry I was not more clear on that. I have just ordered them from OPGI, so hopefully I'll have some more data for my little experiment by the end of the week.
Old January 27th, 2019, 08:49 AM
Thank you Chip
Old February 2nd, 2019, 07:02 AM
Thank you Chip
Just got my new grille moldings in from OPGI and they were a perfect fit for the metal grille on my '71 supreme. No drilling needed. The only thing that makes sense is that these repros were made for metal grilles. Every person that I have read on this site that tried to use them for their plastic ones has had to drill new holes for the tabs or use some other way to adhere them.
Old February 2nd, 2019, 04:53 PM
Thank you for the update Chip.
Old February 2nd, 2019, 05:12 PM
71 cutlass convertible
lshlsh2's Avatar
This is good to know.
lshlsh2 is offline
Oldsmaniac
February 4th, 2017 10:41 PM
costpenn
May 13th, 2016 05:36 AM
bigrig12
August 19th, 2015 02:41 AM
KDW
December 25th, 2013 08:54 AM
ManCutty
February 25th, 2012 05:05 PM
Quick Reply: maybe solved the repro "grille molding" fitment issue?
