Decoding my car
Old January 21st, 2019, 12:30 PM
JD63's Avatar
Decoding my car
Hi I just bought this 69 olds where do I go to decode the numbers. Thanks
JD63 is offline
Old January 21st, 2019, 12:41 PM
72 Olds CS
RetroRanger's Avatar
You can post a pic of the data tag on the cowl some members here can decode or I believe there is an online data tag decoder ( accuracy may vary)
RetroRanger is offline
Old January 21st, 2019, 12:54 PM
Post a pic here
Jamesbo is online now
Old January 21st, 2019, 05:33 PM
Randy C.
rcorrigan5's Avatar
Saw the post of your trim tag. For review, here's what I saw.
ST 69 34487 OS 52814? BDY
TR 930 757510 PNT
12D D55 M21
You have a car that was made in Oshawa, Canada, and there is a source in Canada (others will chime in with the specifics so you can access it) that gives a lot of detail about your car, including what was on the original window sticker. Unfortunately, this service is available only to cars made in Canada. The cars made in the U.S.A. don't have this back-up available.
ST 69 = style/model year = 1969
34487: 3 = GM division = Oldsmobile; 44 = model series = 4-4-2; 87 = body type = holiday coupe
OS = assembly plant = Oshawa Canada
52814? = Fisher body number (has no relationship to the VIN; this number was assigned to the body by Fisher before it got to the assembly plant.
TR 930 = interior color & front seat type = black interior with bucket seats
757150 PNT = lower and upper body colors but I don't have the break on how the Canadian cars used this code. Someone else will chime in with the details.
12D = time build code = December (12), fourth week of that month (D), 1968. Your car was assembled around Christmas time.
D55 = option code = front compartment console
M21 = option code = close ratio 4-speed transmission.
With that transmission, if it is still original to your car, it would be interesting to discover the differential in your car. If the differential is original, I suspect it would be either a 3.42:1 or a 3.91:1 ratio. As well, it would be interesting to know if you have drum brakes all around or if it has the factory disc brakes up front.
Randy C.
rcorrigan5 is offline
Old January 23rd, 2019, 05:16 AM
75 75 is Aztec Gold upper and lower body color
10 is Ebony Black stripe color
joe_padavano is offline
Hark442
October 25th, 2016 10:14 AM
Big Features
March 28th, 2016 07:39 AM
Krom
September 24th, 2015 04:29 PM
papsmac
April 30th, 2014 12:07 PM
sammy
April 20th, 2012 04:58 PM
Quick Reply: Decoding my car
