Oil Filter Housing Gasket....
Old January 14th, 2019, 09:23 PM
spencer83's Avatar
Im in search of a gasket for the oil filter housing. It didn’t come with one so now I’m on the hunt to find one. Thanks in advance
spencer83 is offline
Old January 14th, 2019, 10:32 PM
v8al's Avatar
It's good practice to identify the year/make/model/engine of a particular part you are looking for.
In any case the gasket you are probably looking for is available on Rockauto or just about any auto parts store.
Here's the link for the "Oil Filter Gasket" for a 1970 Oldsmobile 455
1970 Oil Filter Gasket
v8al is offline
Old January 15th, 2019, 02:29 AM
spencer83's Avatar
1987 Cutlass Supreme, 77-80 350 sbo
Old January 15th, 2019, 05:48 AM
Burd's Avatar
I had to make one when I took mine off my TA. Used an exacto knike to cut one out of a sheet of material. I bought a set of punches at a swap, it’s an easy gasket to make if you can’t find it. Inline tube may have one, Those guys are Olds too.
Burd is offline
Old January 15th, 2019, 06:20 AM
BSiegPaint's Avatar
I just replaced the same on my '70 - Autozone had them in stock. your part number should be FelPro 9948 for a '77 350.
https://www.autozone.com/collision-b...ket/580461_0_0
BSiegPaint is offline
Old January 15th, 2019, 06:25 AM
FelPro P/N 9948 fits every 1964-1990 Olds V8 and is available everywhere. RockAuto has them for $1.37. Why would you waste the time to make one?
By the way, if you type oldsmobile oil filter housing gasket into Google, millions of sources come up...
joe_padavano is offline
Old January 15th, 2019, 08:06 AM
spencer83's Avatar
Thank you guys so much for the help.
Gascoop
July 24th, 2018 08:59 PM
RustyOlds
February 7th, 2017 11:35 AM
ostie13
October 2nd, 2016 08:49 AM
Seacar
24
May 13th, 2014 07:45 AM
davidstereo
May 14th, 2012 08:09 PM
Quick Reply: Oil Filter Housing Gasket....
