power steering pump
Old January 12th, 2019, 04:47 AM
deadeyejedi's Avatar
power steering pump
not sure which power steering pump to buy for my project .im putting a 74 toronado 455 into a 80 cutlass and need to get a power steering pump.i have all the original pulleys and brackets for the 74 but not the pump and reservoir .could i disconnect the pump and reservoir from the 1980 307 olds motor in the car now and simply reconnect it to the 455 brackets? or will the lines from a 74 toro pump connect up to the 1980 steering box ?ive checked rock auto and get different part numbers for each application .thank you
deadeyejedi is offline
Old January 12th, 2019, 05:35 AM
All the Saginaw pumps have the same pump body. Only the sheet metal reservoir differs from year-to-year and application-to-application. Use the 1980 pump, brackets, and lines. This will all bolt to the 455. Just be sure to use the spacers in the right places.
joe_padavano is online now
Old January 12th, 2019, 08:35 AM
thanks again joe
Classics65
August 22nd, 2016 05:09 PM
csouth
October 16th, 2015 09:05 AM
yalikeme
August 16th, 2015 08:59 AM
197064buickspec
July 1st, 2014 03:08 PM
sweet70oldz
Brakes/Hydraulic Systems
June 30th, 2012 01:21 PM
Quick Reply: power steering pump
