True SX?
True SX?
Hey Guys and Gals,
New to the site but not new to Olds Cutlass. Had a Cutlass in my younger days and had to sell. Sorry I did every day since. Been on the look out for another car and fell into a 1970 Cutlass SX. I have read up on these and want to make sure the car is a true SX and not a clone. Is there any designation in the VIN or elsewhere that I can verify when I go to look at the car?
Thanks for all your help and I am sure I will need more if I get this car. The interior looks identical to another SX I have seen on line, but again that does not mean much.
Paperwork is the best bet. make sure that the vin derivative on the block matches up to the title and the vin plate at the base of the drivers side windshield. The interior means nothing, as these could be equipped with any interior offered on the Supreme, buckets or bench seats, column or floor shift auto with or without a console.
1969w3155, Thank you for the quick response. As I remember the number stamped on the block is the first letter + last 8 of the VIN in the windshield and title, is this correct? and where is the number on Oldsmobile blocks? Is there anything that designate it an SX in the VIN? Or will it be noted on the title? I am just trying to figure out how to tell when I see the car. It is nice but needs a lot of work. It is supposed t run and be driveable. Is there any difference on the frame or the drive train?
Nothing in the VIN will indicate that it is an SX.
Location of VIN on engine block. Typically hard to see because of power steering/alternator so bring some rags to clean the location and use a camera/cell phone to take a picture.
Thank you vey much. So I can assume if the 455 engin numbers match the VIN then it is an SX? I was hoping for something in the build option plate, which I do have a picture of this plate. Just not the VIN, yet.
Your best proof? A build sheet or broadcast card with the Y-79 Supreme Performance Package option on it. Look under the bucket seats or in the bucket seat backs, under the carpet on either side if it's a bench seat car, under the back seat, or under the rear window package tray if it is a Fremont-built car. If its built anywhere besides Lansing, on top of the gas tank is a possible build sheet location too.
Besides paperwork, if it is a 455 2 barrel (L-33) with an OD transmission, it may or may not be an SX. Regular Supreme hardtops were built with that drivetrain. Not many, but I did document several of them for the SX website archives over the years.
If it has a 455 4 barrel and OG transmission that both match the VIN, yes it is an SX and you got really lucky since it is the more desirable W-32.
If it is a 455 4 barrel (factory, not added on) with OD trans (L-31) and both match the VIN, then you have an SX as well.
Let us know what you find. Also, I have tracked these cars assertively for almost 20 years and have many photos and ad screencaps. If you PM me what you're looking at I may be able to tell you if I know of the car or if it is in the sx455.com registry already.
Terry
Terry,
Thank you for that really informative post. I think it has the 4bbl carb BUT the rear bumpers do not have the cut out for the exhaust. I will get some pictures and send them to you via PM. BTW I did see your website and I really wished the website had a limited free access for guys like me. If this is an SX I do plan on joining the sx455.com website.
Thanks again!
Thanks again!
That is a great catch! I thought the turn lights were square in earlier models, but I was not positive. So it is a safe bet this is not a true SX. I will still go check it out and look at the drive train and then make a determination if I want to mess with it!
I will keep you guys posted. If you can think of anything else please let me know!
Don,
I am not sure. it is located at a car lot in Huntsville, AL right now. I will go check it out but at this point I am not sure it is worth buying especially at the price he is asking. If I can get him down after pointing out the obvious wrong parts on it, I might get it. I love that year Cutlass and loved my 72.
Here is the video of the car when it was at the auction. The guy said he had the car researched at sx455.com and it is an actual Cutlass SX, but that is what he told me.
What do you guys think about the car? Can it be restored? I can work metal and weld but I am almost afraid it is a little too much for me, but I like a challenge!
Oversized battery tray on drivers side
Windshield washer bottle on passenger side(not present)
Under fender braces(by hood hinges), used only on hardtop 455 cars.(not present on this car)
Correct gas pedal for a T400 car
Best indication its not worth the price is that its being passed around by local auctions. First dealer couldnt sell, so it goes to auction, second seller cant sell, so, it'll go to another auction.
I wouldnt consider it until it was put on a lift and I checked the frame and underside for collision damage and rust.
Just watched the video, the fenders, rear filler panel, roof, are loaded with bondo. Probably means rea quarters and doors are the same. this car would cost more to restore correctly than what its value would be when done.
OK, let's start here: It has the SX fender badges and cutout rear bumper, correct?
Terry
Terry
I completely agree. You definitely know the SX!!
I have looked at this car previously, not in person, but through video and pictures on-line. I think your offer of 3K was very generous on your part for this car. I am actively seeking to purchase another SX, specifically a W-32 car. I have passed on this one and many others so far. I have found one of the nicest examples in existence out there for $20,000, and would have grabbed it in a second, but it does not have the W-32 option that I am looking for.
