1969 400 fly wheel
Every single RWD Olds V8 built from 1964-1990 came from the factory with a 166 tooth externally balanced flexplate or flywheel. Most on-line vendors like Summit and Jegs will give you Chevy flywheels if you search for Oldsmobile, which is why you see 168 tooth options. Those are NOT Oldsmobile flywheels. Note that the 64-67 motors use a different crank flange bolt pattern than do the 68-90 motors, so be sure you get the correct one. All 68-90 RWD Olds flexplates interchange.
3g87xm
January 4th, 2014 08:37 AM
